Main Bearing Issue
7 replies to this topic
#1 colinf1
colinf1
  • 1,016 posts
Posted 24 December 2021 - 03:21 PM
I'm in the process of rebuilding my A+ 998.
Ordered main bearings based on year (1983) and only looked at block side that have side tags.
Now I've just realised I needed 3 side tag and 3 center tag bearings.
Could I file down the tag and use them?
It's just a bit of a pain ordering anything for the UK to Ireland...
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 24 December 2021 - 03:27 PM
Personally I'd carefully grind/file the groove in the caps.
#3 colinf1
colinf1
  • 1,016 posts
Posted 24 December 2021 - 03:46 PM
That will be the plan then!
Would you keep the tags on the same sides or do them opposite?
#4 GraemeC
GraemeC
  • 7,438 posts
Posted 24 December 2021 - 03:53 PM
Same side, then if there is a future rebuild there is no confusion about which way round the cap goes - tang to tank will always be the same.
Just make sure the grooves are deep enough and wide enough - you don't want them being a little too small and pushing the shell into the crank.  At the same time, you don't wan them too wide that the shell can walk sideways.  Take your time and use and old shell to keep checking.
#5 nicklouse
  • 18,615 posts
Posted 24 December 2021 - 05:05 PM
Or just reorder the correct bearings.
#6 colinf1
colinf1
  • 1,016 posts
Posted 24 December 2021 - 06:23 PM
Yes, that seems more sensible thing to do.
Considering my impatience I think it's best to reorder correct bearings.
I can get on with my gearbox rebuild while waiting patiently..
#7 mini13
mini13
  • 3,810 posts
Posted 31 December 2021 - 12:25 PM
The centre tang bearings are the later uprated "turbo" bearings that have the groove deleted.
I've modded the caps to take them in several engines, its fairly simple with a file or dremel.
#8 colinf1
colinf1
  • 1,016 posts
Posted 20 January 2022 - 02:23 PM
To close off this topic, I re-ordered the correct bearings, 3 center, 3 side tags.
The side tags that came with new set are identical to the 6 from the other set, barring a code on the back which was the same code on the 3 side/3 center and a different code on the 6 side tag bearings.
