Not had much time of work but got a week off in a weeks time so car is booked in for its MOT.
In the meantime I stripped down the two engines I got a good few years ago to have a look at what I can and cannot use for my first engine build.
First engine stripped
20220409_173628.jpg 90.84K
1 downloads
Block is in a not bad condition bores have little marking and all threads are good. There is no engine number plate on it so ill assume its be skimmed.
Standard timing change
Cam bearings seem ok and cam does not seem to have any wear I can see on the lobes, and cant find any markings so assume its a metro cam as these engines came out of metros
Mains bearing look ok too
20220409_173655.jpg 54.97K
0 downloads
Pistons are 20831 L2 STD with A in the centre
Crank is scrap deep gouges in the end. The end float was 0.010 thou with STD and 003 thrust washers but seemed worn.
20220409_173716.jpg 52.34K
1 downloads
Second engine stripped
20220409_173635.jpg 100.29K
0 downloads
Block again is not a bad condition and all threads are good. Again this does not have the engine number so assumed it has been skimmed.
Duplex timing chain
Cam bearings look ok and same again cam does not look to have much wear on the lobes and cant find any markings so again assume its the metro cam.
Main bearing look ok too
20220409_173707.jpg 57.88K
0 downloads
Pistons are 20831 +20 with B in the centre
Crank looks in good condition all with STD bearing end float was 0.03 with STD thrust washers on both sides
20220409_173712.jpg 54.4K
1 downloads
Here are the cranks
20220409_173647.jpg 55.34K
1 downloads
Here the heads, stripped down and gave them a quick clean. The top head has a T scribed in it near the heater valve does anyone know what that means? Had a look around possible metro turbo head?
20220409_173940.jpg 64.34K
1 downloads
20220409_173925.jpg 59.51K
1 downloads
Here are the two gearboxes one has slight rust on it but there other is well oiled and looks good
20220409_174108.jpg 60.42K
1 downloads
I have no ideas what i want to build so need to have a good think, and do some more research
Edited by weeally, 09 April 2022 - 11:05 PM.
