Oil Pump For 998 And 1098 A+ And A-Series
5 replies to this topic
#1 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 02 January 2022 - 08:13 PM
I've had a search but can't find an answer. So the question is, can a 998 A+ slot drive oil pump fit a Pre A+ 1098 engine? I've read there are different bolt locations? Can they be modified to fit if not?
It's so an A+ cam (minispares evo1) can be fitted to the 1098 block (I guess fitting an A+ cam into a Pre A+ is doable)
Cheers Alex
#2 nicklouse
  • 18,697 posts
Posted 02 January 2022 - 09:23 PM
The pump you fit is defined by the drive on the cam. That is the only defining point.
#3 alex-95
alex-95
  • 6,042 posts
Posted 02 January 2022 - 11:11 PM
Cheers, That will make life easier!
#4 Spider
  • 15,146 posts
Posted 02 January 2022 - 11:51 PM
There is another defining point, that being a small or big bore pump.
There was some small bore blocks late 60 / early 70s that were drilled and tapped for 4 bolt fixing (they had these with the spider drive pumps) for which the bottom 2 holes should line up and just the top one needing to be drilled & taped if going to a 3 bolt pump.
#5 alex-95
alex-95
  • 6,042 posts
Posted 03 January 2022 - 10:48 AM
:thumbsup: Cheers mate, I think thats what I read on a few threads just couldn't get a definitive answer. we can drill and tap that easily then if required.  The unused holes wouldn't need blocking up if they are through holes would they?
#6 Spider
  • 15,146 posts
Posted 03 January 2022 - 05:15 PM
There's no need to plug them up, they are (or should be) blind holes.
