How To Repair Previously Cut Front Arches...
7 replies to this topic
#1 JamesAlexander
JamesAlexander
  • 51 posts
Posted 06 January 2022 - 08:41 PM
Hi folks,
I’ve discovered today after taking off my bent front arches that they are bent to hide the fact that the arches have previously been cut away to accommodate 13” wheels much to my dismay.
I’m running 10” wheels and want to put this back to standard, the cut away is across both the front of the wing and the front panel so my question is has anyone had to deal with this?
I haven’t ever seen a front arch replacement panel so I’m hoping it’s not two new wings and a new front end?!!
Many thanks in advance!
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,898 posts
  • Name: Neil
Posted 06 January 2022 - 09:48 PM
No repair panels for this i'm afraid, but if you have a shrinker / stretcher it would be possible fabricate new lips.
You will need some folded 0.9mm steel sheet to start with. BUT all of this is a lot work and if you cannot weld / fabricate then new wings would be easier. You can by new front panel corners so you could take off them what you need. It all depends on how well the wings / front panel have been cut to start with.
#3 sonikk4
sonikk4
  • 15,898 posts
  • Name: Neil
Posted 06 January 2022 - 09:50 PM
Oh and i have hidden your other identical post in the problems section as this is the correct area to post it.
#4 Tupers
Tupers
  • 4,105 posts
Posted 06 January 2022 - 10:01 PM
As mentioned above you can’t get repair sections for the wings but you can get rear quarter repair pieces which will give you the curve and should have enough meat to correct the clearancing that’s been done for 13” wheels. https://www.minispor...pair-panel.html
#5 sonscar
sonscar
  • 2,724 posts
Posted 06 January 2022 - 11:05 PM
If you can weld car bodywork then it is an easy task to form the missing arch and weld in position.If you can't weld then it could end as a full restoration( only jesting),Steve..
#6 JamesAlexander
JamesAlexander
  • 51 posts
Posted 07 January 2022 - 08:49 AM
Cheers folks, yes I can weld, good idea about using the rear quarter panel to get the metal to make up the front, cheers!
#7 JamesAlexander
JamesAlexander
  • 51 posts
Posted 07 January 2022 - 08:52 AM
Front panel corners good idea too then fabricate the little bit of wing that’s missing, excellent food for thought, cheers!
#8 Ethel
  • 25,416 posts
Posted 07 January 2022 - 10:44 AM
Those repair panels seem pricey. Shouldn't be  hard to cut a wooden former & knock over your own.
