Hi all,
My wife has had her 1992 Rover Cooper for almost 20 years now, and at one point the engine was 'replaced' for another one due to an piston ring failure. This was before we knew eachother. The Cooper was stored for 6 years, and now has new MOT, so we enjoy driving it again.
I said 'replaced' as this was not a straight engine swap. The block is currently a 12A2DF75 which is a regular SPI block. However the car is still carbed, so HIFF44 it has the cast 'LCB' style manifold and Rover alu intake manifold, so the old hardware is changed to the new block.
However I do not know if they changed the cilinderhead and camshaft, which where higher compression and had a different profile as it was a Cooper engine. As the swab was done by the most well known Mini specialist in Holland at the time I reckon that he made sure the engine was in the same spec, but we cant tell for sure with the engine in the car.
So a question for the people with endless Mini knowledge. Could you tell the difference in camshaft profile while driving the car? So does the Cooper cam pull from an to a certain RPM which is noticeable different from the stock camshaft. Or is the powercurve nearly the same, only more powerfull across the range?
I'm currently waiting on a Maniflow stage one kit with stage 2 lcb and RCM, so will be taking it to a dyno in a month or two, but I would really like to know how to spot the difference between the cams.
Thanks in advance,
Dennis
