Hello
I have a 69 850 that I believe has previously been upgraded from magic wand to remote gearchange. The gearchange is rather loose and vague and makes finding gears a slow deliberate process. Also it is difficult to get 3rd gear without a crunch, when coming down from 4th. I am under the impression that the remote change should feel better than this.
Im taking the engine out at the moment to upgrade to an A+ 998 however Im not sure what to do about the gearbox.
Option 1 I take the opportunity to get the gearchange right and refresh whatever is wrong with the early remote box. Can anyone take a stab at what this might need or entail? is it likely to be an issue with the shift mechanism or something within the gearbox? I think I need to change the drop gears to fit this to the A+ engine?
Option 2 I change to the A+ gearbox and add a rod change and replace the rubber couplings with pot joints. On the downside, I hear that the rod change is inferior to a good remote change, and I presume I have to change driveshafts and hubs which is more hassle?
I think I'd prefer option 1 but Ive never dabbled with a gearbox before so its the unknown for me - would problem areas likely make themselves obvious if I start pulling it all apart?
What are your thoughts please?
Ben
