Home Chemical Cleaning
8 replies to this topic
#1 Gaz66
Gaz66
  • 963 posts
Posted 13 January 2022 - 09:02 AM
Is caustic soda ok to clean engine parts and gearbox castings?
#2 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 13 January 2022 - 09:56 AM
Don't use it on anything made out of aluminium.
Diesel is good, or if can get hold of it Kerosene which is basically paraffin - cheaper too.
Used jizer degreaser to good effect too.
Don't ever use petrol, my Dad burnt the skin off his face, hands and right leg washing a motorbike crankcase out in petrol - the fumes were lit by a fluorescent light fitting starting.  Blew up in his face with his hands in it, fell backwards and the bowl spilt on his leg.  Took him ages to recover and I can still remember it 50 years on.
Edited by DomCr250, 13 January 2022 - 09:56 AM.
#3 RooBoonix
RooBoonix
  • 1,225 posts
Posted 13 January 2022 - 10:56 AM
I use a citric acid bath for rust removal, removes rust relatively easily and it's not overly aggressive. You can buy it in powder form from ebay. I find it works well enough at 10% concentration.
For degreasing I use whatever I have to hand, I normally have some sort of degreasing chemical about but as DomCr250 mentioned above Kerosene is a good one.
#4 Gaz66
Gaz66
  • 963 posts
Posted 13 January 2022 - 11:01 AM
I'm mainly wanting to clean gearbox castings and need something that will not only degrease but take old paint off too.
I want the castings "as new"
What do the pro's use to do this?
#5 GraemeC
GraemeC
  • 7,440 posts
Posted 13 January 2022 - 11:28 AM
Usually either chemical stripping or blasting with the right media - aqua-blasting probably being the best.
#6 Gaz66
Gaz66
  • 963 posts
Posted 13 January 2022 - 07:33 PM
This is what I want to know ideally. The chemical used.
#7 floormanager
floormanager
  • 718 posts
  • Local Club: Mini Club Sussex
Posted 13 January 2022 - 07:43 PM
A case I bought had been aqua-blasted.  It was completely clean.
#8 Spider
  • 15,141 posts
Posted 13 January 2022 - 09:52 PM
I used to have a hot tank of caustic. Works a treat on cast iron, steel etc, but don't use it on alloy bits.
Heating it makes it work much faster, but even cold, it works well, just takes longer. It's good for removing some paint, but works well on oil, grease, carbon deposits etc. It won't do a thing on rust.
You will want to really flush the parts well after as the caustic is alkali.
I used to follow the (hot) caustic with a cold acid bath to remove rust.
#9 RooBoonix
RooBoonix
  • 1,225 posts
Posted 14 January 2022 - 04:51 PM
At my old workplace we used a strong alkali bath, Metsoak was the brand can't remember the exact product, but I know it's not readily available to the public. Nasty stuff.
Any items used to get dunked for as long as needed to remove paint, carbon etc... then sandblasted to remove corrosion. If a nicer finish was desired, or if it was aluminium and wasn't going to be painted, then the vapour blaster was used.
