Scuttle Vin Number - Where To Get Star / Asterisk Character?
3 replies to this topic
#1 bobheinen
bobheinen
    Starting My Mini Up
  • 2 posts
Posted 16 January 2022 - 08:32 PM
Hi guys, I've been looking for an asterisk stamp as used in the scuttle VIN, for quite a while.
The only stamp I've found is the stamp from McMaster: https://www.mcmaster.com/1574T371/
Is this the exact / similar asterisk in size & shape as the original VINs from 1980 on?
If not, does anyone have a better suggestion where to find one (preferably in the Netherlands or Europe)?
Thanks a bunch!
#2 colinf1
colinf1
  • 1,025 posts
Posted 17 January 2022 - 11:36 AM
I used an "I" and built it up to be an asterisk with a vertical, horizontal, then one at 45degs to left and one at 45degs to right.
#3 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 17 January 2022 - 12:27 PM
Plenty of local shops with a quick search to stars/asteriks'
https://www.vocor.nl...6947020501.html
https://www.stempels...tempel-ster-4mm
https://www.stempels...el-asterisk-6mm
https://kralenwinkel...agstempel-ster/
Measure one and it should be pretty easy. Alternatively: have you tried asking in the Dutch Mini Seven Club?
#4 bobheinen
bobheinen
    Starting My Mini Up
  • 2 posts
Posted 18 January 2022 - 09:12 AM
@colinf1, thanks! I read that somewhere as well. Did you do it freehand? What's the end result like?
@Spherix, thanks for your suggestions. These stamps I found as well, but they all look square instead of rectangular. Also, they have 6 points instead of 8 in the original VIN number.
It seems that the Dutch Mini Seven Club is quite agressively monitoring and modding any question regarding stamped VIN numbers and stamps. That's why I asked on this forum, which also has a broader and more active membership base.
Edited by bobheinen, 18 January 2022 - 10:14 AM.
