Intermittent Starting Issue
7 replies to this topic
#1 Abzero
Abzero
  • 17 posts
Posted 22 January 2022 - 10:47 PM
Got an odd issue with a 1990 Mini City Auto.
When starting sometimes the starter motor turns over just fine, sometimes I just get a click, if I get the click if I keep trying eventually the motor starts up. Occasionally when the motor is running, it suddenly stops.
The starter motor is a new unit, as I thought the old one was duff (when through the haynes manual check list, and things like the lights dimmed when the key was turned etc.)
Battery is charged and relatively new. Starter motor is new. Interlock isn't the issue as you don't get the click if its in gear.
Any idea's on what to inspect and check?
Thanks in advance.
Edited by Abzero, 22 January 2022 - 10:48 PM.
#2 gazza82
gazza82
  • 3,025 posts
  • Local Club: TMF+
Posted 22 January 2022 - 11:18 PM
Is it the correct starter? There are two different gears with different numbers of teeth. get the wrong one and occasionlly it could jam on the flywheel
#3 johnR
johnR
  • 2,303 posts
Posted 22 January 2022 - 11:27 PM
The click could be a failing starter solenoid or relay, the engine stopping could be a variety of things probably unrelated?
#4 croc7
croc7
  • 819 posts
Posted 23 January 2022 - 06:09 AM
[quote name="johnR" post="3712576" timestamp="1642894059
Fat finger issue….
Edited by croc7, 23 January 2022 - 06:19 AM.
#5 croc7
croc7
  • 819 posts
Posted 23 January 2022 - 06:17 AM
Agree with JohnR. You have two separate issues, one sounds like an ignition problem, the other with the starter system. I had an intermittent slow start problem that was traced to a bad solenoid-I took it apart and was amazed that any current was getting through at all, that’s how corroded the contacts were. I’d also have a peek at the ground strap connection.
#6 Abzero
Abzero
  • 17 posts
Posted 23 January 2022 - 11:14 AM
Yes, by engine stopping, I mean the starter will cut out mid trying to start. Its not starting well at the moment, because its cold and doesn't get alot of driving anyway. But once the engines going it's fine and doesn't cut out.
#7 Abzero
Abzero
  • 17 posts
Posted 23 January 2022 - 11:15 AM
I believe so, the new unit and old unit look identical (one being alot cleaner than the other however.) I didn't count the teeth however.
#8 Abzero
Abzero
  • 17 posts
Posted 23 January 2022 - 11:16 AM
Thanks both, i'll inspect the solenoid and the ground strap and hope that solves the issue.
