I'm building a 1380 track/hot road engine for my friend Gavin,
All A+ engine
73.5mm omegas/7cc dish fitted to balanced rods,
Rings gapped to 15/16 thou,
Pistons set flush to deck for minimum squish/best det elimination,
Fully balanced 10/10 crank assembly along with MED front pulley and
MED st2 light flywheel/pre verto clutch set up,
Gavin modded clutch wok,
Piper 280 custom grind with modded LCAs to suit the A series ports/valve train,
MED 1.5 roller rockers,
MED Vernia set up,
All relevant fixings ARP,
Rebuilt late A+ gearbox with 3.44 X-pin diff,central oil pick up,
MED straight cut drops/ floating bearing type,
JMR race spec head with 11/1 comp,
MED 40 thou MLS headgasket,
Maniflow large lcb/maniflow system,
Maniflow polished stainless 6.5 inch inlet with Weber 45,long trumpets,
Alden dizzy,
Large pipercross air filter,
Edited by Tones61, 23 January 2022 - 08:13 PM.
