Hi all,
I plan on cutting some valve seats myself using HSS cutters I'll be buying in the right sizes for the 202 head I'm reconditioning (no hardened inserts). Apparently they can make the pilot spindle which goes in the reamed valve guide any size I want. Advice from this forum has suggested that a size of 7.1mm would be too loose to make a good seat. The valve guide size of 9/32" equates to 7.143mm (0.28125"). Should I get it 7.14mm (0.2811") ? This is a very close fit and would hold it true, I could linish it down slightly if it was way too tight. Any thoughts before I make the purchase?
*Yes I know I could get the seats cut professionally but where is the fun in that?
