IMG_20220125_1453214~2.jpg 33.59K 0 downloads
Should I be concerned that it might lead to corrosion to outside sealing surface?
Edited by Tornado99, 25 January 2022 - 11:21 PM.
Posted 25 January 2022 - 11:20 PM
Posted 25 January 2022 - 11:59 PM
It's not ideal. You'll find in time that moisture will get under the edges and cause rusting - as you suspect. No issue if it's on the inside, but you can be sure, it will travel once started, to the outside.
While quite a bit dearer, I prefer Stainless Pistons.
Posted 26 January 2022 - 12:45 AM
Stainless was not offered by my local supplier.It's not ideal. You'll find in time that moisture will get under the edges and cause rusting - as you suspect. No issue if it's on the inside, but you can be sure, it will travel once started, to the outside.
Edited by Tornado99, 26 January 2022 - 12:45 AM.
Posted 26 January 2022 - 06:35 PM
