Ball Joint Rebuild Kit
Posted 25 January 2022 - 11:26 PM
One of the "socket caps" seems to have some sharp edges and roughness, sufficient that the swivel action of the stud is heavily impaired. Should this just be ground down with a dremel or should it be considered defective and returned?
Posted 26 January 2022 - 08:07 AM
Posted 26 January 2022 - 06:33 PM
The retailer has informed me he will be sending out a replacement anyway.
Posted 26 January 2022 - 07:38 PM
Sadly, most ball joints available these days don't seem to be 'fitable' out of the bag as they once were, the OEM items had a ground finish, where as the commonly available items I've seen look to be a turned finish, I guess the grind finish is now left to who ever is doing the fitting. I've also found they don't have a hard case like the originals.
Just to put it out there, while many of us know of the sealed maintenance free joints out of Japan, they also have some 'OEM' type ball joints. I bought and fitted these up to a friend's car. They had a ground finish and to me, seemed every bit as good as the originals. Somewhere in the next few months, I'll be inspecting them, I'm quite keen to see how they are fairing.
Posted 03 February 2022 - 06:26 AM
Possible for you to send me your feedback direct about the OEM ball joints?
Posted 03 February 2022 - 10:16 AM
I'll be sure to post them up on the forum
Posted 03 February 2022 - 08:11 PM
Classic Mini parts Japan sell maintanance free ball joint kits https://www.facebook...ewAndUsedParts/ and speak to David
Posted 03 February 2022 - 09:18 PM
Yup. Have seen these quite a while back. But they work out to over $80 (CAD) per joint....whereas rebuild kits run about $20 for a pair.
Posted 04 February 2022 - 01:59 AM
I just recently fitted a set to my own car. These come with limited grease in them and from David's webpage, it's recommended to grease them in the normal way on fitting, but that should be the only greasing they need - I dare say for normal usage.
I did machine up a blank to take the place of the spring in the lower joint otherwise as I saw it, the 'plastic' seat will have next to nothing to seat on.
And yes, I'll be sure to give a review once I've done some miles (kms !!) on them.
Posted 04 February 2022 - 02:48 AM
Are these the same ball joints?
Edited by xrocketengineer, 04 February 2022 - 02:49 AM.
Posted 04 February 2022 - 10:20 AM
Good result on supplier sending replacement.... almsot and admission of guilt.
Posted 04 February 2022 - 01:15 PM
Always make sure your balls are well lubricated and free to move when required.
Always! You don't want them to get pinched.
Posted 04 February 2022 - 09:10 PM
Posted 04 February 2022 - 11:44 PM
ClassicMiniJapan also now offering heavy duty shimmable balljoints:
https://classicminis...em-ball-joints/
Still pricey at 10,780 YEN...($120 CAD) per pair. Unclear but presumably this is before shipping/duty etc.
Posted 05 February 2022 - 12:25 AM
That's them that I referred to in post # 4 above
