Electric Heater
18 replies to this topic
#1 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 26 January 2022 - 11:45 AM
Hi Everyone, Just wondered if anyone has swapped out the normal heater for an electric one? I've got a 1989 mini with a heater than never gets warm and want to swap out for an electric one :)
#2 Arthy
Arthy
  • 112 posts
Posted 26 January 2022 - 12:12 PM
I had this problem, turns out I had a blocked heater matrix! Mine never really has a problem getting warm now, even near freezing point.
I'm sure one of the guys on here though have fitted an electric one.
#3 Ethel
  • 26,074 posts
Posted 26 January 2022 - 12:25 PM
You've got free heat from the cooling system, a surprising amount of it that your alternator isn't going to be able to match in supplying.
#4 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 26 January 2022 - 12:38 PM
I might look at swapping the matrix radiator then when the engine comes out this year then :)
#5 Quinlan minor
Quinlan minor
  • 1,206 posts
  • Local Club: LSMOC
Posted 26 January 2022 - 01:20 PM
Might be worth trying to flush it.
#6 Arthy
Arthy
  • 112 posts
Posted 26 January 2022 - 02:43 PM
+1 for this, but I don't think they're expensive for a new one if I remember correctly!
#7 roblightbody
roblightbody
  • 448 posts
Posted 26 January 2022 - 09:59 PM
If everything's working properly, a mini's heater should give out roasting hot air. Speaking as someone who had a 1989 mini brand new back in the day!
The only issue is the relatively low volume of air compared to a normal car, but it's enough to heat the interior even on the coldest of days.
Edited by roblightbody, 26 January 2022 - 10:00 PM.
#8 Indigo
Indigo
  • 52 posts
Posted 27 January 2022 - 06:19 AM
I had a similar problem - heater not working.
Swapped the thermostat from 72 degrees to 84 and it made a world of differance.
#9 coopertaz
coopertaz
  • 807 posts
  • Local Club: a-series-magpies
Posted 27 January 2022 - 11:28 AM
get new matrix and flush all system then change thermostat at same time. easy job and relatively cheap, as if matrix is blocked will more than likely leak after flushing.
#10 Ethel
  • 26,074 posts
Posted 27 January 2022 - 12:20 PM
Could be the thermostat, but flushing is free & worth a go before buying bits.
I'd agree about leaks if it was an all tin matrix, but the later type with plastic ends are more robust. Guess it depends if you can manage without the car, or heater, for a wee while.
#11 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 27 January 2022 - 12:31 PM
Heater matrix's are on offer at P and L minis so may go up and get one on a day off :)
#12 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 27 January 2022 - 04:34 PM
I dont use my car that much, but I have the heater matrix constantly running with coolant, ie there is no water valve to turn it off. Its very toasty indeed, sunroof open when too hot in the winter / or window, and in the summer it provides extra cooling. Like I say I dont use it often (enough!). Plenty of heat :-)
#13 Tornado99
Tornado99
  • 750 posts
Posted 27 January 2022 - 06:14 PM
My '88 mini has about the most effective heater i've had in any car. It gets the heat into the interior quite rapidly and after ten minutes I find I need to turn it off as things get too hot. This is likely more to do with small interior volume compared to other cars. I guess having the two side vents permanently sealed off is also a factor.
#14 mini-mad-mark
mini-mad-mark
  • 865 posts
  • Local Club: northants wot no brakes
Posted 30 January 2022 - 09:39 PM
I have a similar problem with my kit car - the hoses are hot, indicating hot water into and out of the matrix (I think - see bottom point).
However the heater only feels lukewarm and as soon as I turn the fan on the blown air goes cold after a few seconds (even though the hoses are still hot) was a new matrix when I rebuilt the car so no blockage.
Could it be an airlock?  - I haven't tried to bleed the system -  by releasing the return from the heater to the bottom hose I think might do that?
Any thoughts?
#15 PoolGuy
PoolGuy
  • 855 posts
Posted 30 January 2022 - 09:50 PM
Check the temps of each pipe, the out pipe will be slightly cooler if the matrix has water flowing through.
