Mechanical Fuel Pump
3 replies to this topic
#1 Jon Misiuda
Jon Misiuda
    Starting My Mini Up
  • 1 posts
Posted 26 January 2022 - 08:23 PM
Hi
My 1960 Morris Mini Minor has a mechanical AC fuel pump. My numbers check out but I can’t find any references to mechanical fuel pumps before 1969. The car looks completely unmolested/original Any info appreciated.
Registration HEY 544
Car No: M A2S4 23528
Chassis number FE37181
Engine number 8MB U-H 20773
#2 eric67
eric67
  • 128 posts
Posted 28 January 2022 - 01:48 PM
Hi Jon, sounds like a good very early car you have there. It’s almost certain that an electric SU pump would have been fitted as standard and most probably it would be a PD type which was later replaced by a SP type in 1961, with a higher fuel delivery rate.
I guess it would be worth checking the wiring loom for any clues of redundant wires - and doubly so if you intend to reinstate an electric pump.
#3 Spider
  • 15,877 posts
Posted 28 January 2022 - 11:13 PM
Best I can find, the 850 retained an electric Pump, as eric67 mentioned above, up until October 1969. They then went mechanical.
#4 Cooperman
  • 23,569 posts
Posted 30 January 2022 - 11:13 PM
I suspect you have a later engine, but the engine number plate has been changed for the original.
