Running In ... And Problems !
7 replies to this topic
#1 mrmeds
mrmeds
  • 266 posts
Posted 29 January 2022 - 06:39 PM
Got new engine put in car and starting to run in. 998 CC, with cooper garages  head and twin carbs.
The head was low mileage but had new valves put in due to damage caused when last engine expired.
Anyway, running in as per instructions, and just started taking up to 3500 rpm , after not going above 3000.
Got up to heady speeds of 60mph for first time on new engine, but now its started spluttering and had total loss of power and car wouldn't start.
Called AA, but due to long wait i tried turning engine again to see if i could go the 100 yards down the road to the pub car park, for safety.
Car started first time , and sounded fine. So cancelled AA , and drove the 4 miles home. But car still seems to occasionally splutter and loose power when throttle opened.
Sounds fine on idle when revved thru to 3500, only seems to happen under strain .
Anyone ideas ' could it be blocked fuel line, as tank was empty for a few months while waiting for work to be done. ?
#2 Spider
  • 15,684 posts
Posted 29 January 2022 - 07:12 PM
It does sound like a fuel issue.
I'd probably start by checking the fuel filter, then fuel pressure and delivery quantity.
#3 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 30 January 2022 - 01:51 PM
Heat shield fitted to the carbs?
#4 mrmeds
mrmeds
  • 266 posts
Posted 30 January 2022 - 06:07 PM
well, been out only around 10 miles, since, on a  variety of roads, hill , straight dual carriageway up to 60.. and it seems to be behaving
#5 mrmeds
mrmeds
  • 266 posts
Posted 13 February 2022 - 07:34 PM
okay went wonky again today.  It does act as though its running out of fuel. The more accelerator you use, the less power there is until it dies. Then after about 20 minutes it seems to work again, though it happened twice todfay
#6 Quinlan minor
Quinlan minor
  • 1,325 posts
Posted 13 February 2022 - 07:40 PM
I know it's a 'back to basics' question, but is the vent hole in the fuel cap blocked?
Next time it dies, whip the fuel cap off and see if it'll start.
#7 sonscar
sonscar
  • 3,198 posts
Posted 13 February 2022 - 08:28 PM
Has it got points and condenser?gap closed and/or condenser failing.Steve..
#8 bpirie1000
bpirie1000
  • 2,539 posts
  • Local Club: Amoc
Posted 14 February 2022 - 07:54 AM
Crimps on the wires at the coil all good and tight?
