Wipers
4 replies to this topic
#1 Shaun78
Shaun78
  • 54 posts
Posted 30 January 2022 - 09:09 AM
Hi all I'm a new member here,I have a 1978 Australian moke I'm restoring,I have a question about wipers I have the the old system with a square motor and link rods but no wiper arms or blades,does anyone know what length they should be.thanks for any help.
#2 Spider
  • 15,016 posts
Posted 30 January 2022 - 06:36 PM
The particular Arms and Blades that were originally fitted were very light and had a fixed flat blade - a very similar arrangement to the early Land Rovers. If memory serves, the blades were 10" and while available, they are quite obscure to find, I always found that because the blades were fixed in a flat shape, they were none too effective if there was the smallest of contaminants on the screen or in heavy rain, they were quite hopeless. I can't recall the length of the arms, but can check if this is what you would really like to fit.
I always took them off, for a while I was fitting Arms and Blades from Minis, while still quite light, have a spring loaded blade and a heavier spring on the arm, these made a big difference. Also, replacements rubbers for the blades are very common.
#3 Shaun78
Shaun78
  • 54 posts
Posted 31 January 2022 - 06:25 AM
Thanks for the reply spider,I do have another wiper motor it came with a mini type wiper motor that uses the worm drive cable,also like the landrover system,would this be the better option to use.thanks.
#4 Spider
  • 15,016 posts
Posted 31 January 2022 - 09:29 AM
The original spindles that the wiper arms mount to, have the same splining as the Minis (and a few other cars) have, so swapping arms is fairly straight forward.
I'm sorry, I'm not familiar enough with the Land Rover wipers to make a call on them in particular, however, I did always find the Moke set up with hard linkages better than the Cable rack system of the Mini.
#5 Shaun78
Shaun78
  • 54 posts
Posted 31 January 2022 - 06:42 PM
Thanks for the info spider,I have a friend who buys and sells at auto jumbles and have some mini bits so will be paying him a visit and find some wiper arms.
