Hs4 Float Valve - Spring
12 replies to this topic
#1 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 04 February 2022 - 06:35 AM
I am recommissioning a 998cc running an HS4 carb. I have stripped it all and replaced a few components where fuel has dried and glued. The float needle and valve seat cleaned up nice and work smoothly now when dry.
Just curious what is the tiny spring loaded pin on the bottom of the valve? Is there an internal valve there within the body of the valve? Or is something to do with the clip that’s connected to the plastic float?
#2 Tds76
Tds76
  • 87 posts
Posted 04 February 2022 - 08:24 AM
I’m guessing that it is the one used to lift the piston up to check it drops easily and mixture setting.
Cheers, Paul.
#3 nicklouse
  • 18,697 posts
Posted 04 February 2022 - 10:14 AM
Picture? Sorry your words are not really leading to a part that exists. There is no spring on the float. There is a spring on the piston lifter but your words don’t match that.
#4 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 04 February 2022 - 10:16 AM
Cheers, Paul.
So that one I found and is on the body of the carb. The one I mean is the tiny little needle that sits inside the fuel bowl, and is responsible for moving up and down as the plastic float rises and falls, and as it does so slides into a seat that either stops or allows fuel in. On that tiny little valve is an even smaller tiny pin that pushes in and out. I was just wandering the purpose of it. Does it operate a second smaller valve within the main, but still small valve..!?
#5 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 04 February 2022 - 10:19 AM
This bit..! Arrowed..
#6 nicklouse
  • 18,697 posts
Posted 04 February 2022 - 11:44 AM
that is a new one on me. Sure all mine were solid.
#7 nicklouse
  • 18,697 posts
Posted 04 February 2022 - 11:46 AM
I see that there are now spring and unsprung versions available.
#8 coopertaz
coopertaz
  • 807 posts
  • Local Club: a-series-magpies
Posted 04 February 2022 - 11:51 AM
new ones with the neoprene tip do have these i thought it was to do with maintaining position into seat. i know the float arm does press on it but that was all i could think of. always worked ok though so never bothered about it, and never had problems with sticking which used to be a problem many years ago
#9 mad4classics
mad4classics
  • 200 posts
Posted 04 February 2022 - 11:52 AM
I think it was added as an anti-vibration feature.
#10 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 04 February 2022 - 02:08 PM
Cheers all for the input. The float is working fine now I have cleaned it and the brass seat, was a bit sticky following a 5 year lay up. Was just wandering about the small pin.
#11 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 04 February 2022 - 02:21 PM
It is there to regulate pressure on the seat / needle tip (it gives a bit of wiggle room before damage to the needle tip will occur)
#12 Miki Leyland
Miki Leyland
  • 125 posts
Posted 04 February 2022 - 04:14 PM
Interesting... my only concern is if these would be also reliable in time
#13 Spider
  • 15,146 posts
Posted 05 February 2022 - 04:58 AM
There were some I believe after market Needles that had this feature. It appears to me it was fitted in an attempt to get the Needle to seat harder in to the Seat. I found this style of Needle none too good or long lasting.
