Exhaust Manifold For Standard 1275
8 replies to this topic
#1 Badger360
Badger360
  • 29 posts
Posted 07 February 2022 - 08:16 AM
Hi all,
I have booked in a roiling road session to get my car all set up, mainly to make sure the carb is all correct.
I was looking to replace the exhaust, it seems like the previous owner has out a Maniflow "cooper free" style 3-1 into a 2 box rc40 system,
looks like it has been on the car a few years and after seeing the state of the cooling system - i thought best to just go over everything a renew or improve,
what does every one suggest ?
Many thanks
#2 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 07 February 2022 - 09:41 AM
Free flow exhaust manifold onto a single box Rc40 side exit system.
You'll maybe lose a couple of bhp but you won't have the Y Pipe to deal with like an LCB type
Edited by cal844, 07 February 2022 - 09:44 AM.
#3 coopertaz
coopertaz
  • 807 posts
  • Local Club: a-series-magpies
Posted 07 February 2022 - 03:39 PM
could go lcb but get stainless one and use correct clamps, not u bolts, on y piece. had one on for years and never siezed on when needed to remove
#4 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 07 February 2022 - 05:33 PM
The issue with the Y piece is getting it not to leak
#5 coopertaz
coopertaz
  • 807 posts
Posted 15 February 2022 - 01:03 PM
exhaust assembly paste and heat up on idle till set. worked every time
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 15 February 2022 - 01:12 PM
Mikalor style clamps and exhaust silicone. You must leave the silicone 24 hours to harden before starting up; if you don't, the exhaust gas will blow the silicone out. Using this method has always given me great results first time.
#7 coopertaz
coopertaz
  • 807 posts
Posted 15 February 2022 - 01:16 PM
theyre the clamps i use on bike but cheaper to use ones that come with lcb. work the same and already there
#8 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 15 February 2022 - 01:19 PM
You pays your money and takes your choice. No right or wrong answer, it's just what we become comfortable with.
#9 Cooperman
  • 23,327 posts
Posted 15 February 2022 - 03:25 PM
I have always used the ones supplied with the Y-piece and have never had any problems. I don't even use exhaust paste.
One thing I always do is weld the Y-piece to the exhaust pipe, then make sure there is plenty of engagement of Y-piece to LCB.
