Whilst trying to locate an oil leak from back of gearbox, I noticed that this bit isn't sitting flush and looks wonky. What is this bit called? Is it cast into the gearbox or a separate item?
Thank you in advance.
Neil
Posted 08 February 2022 - 09:15 PM
Posted 08 February 2022 - 09:24 PM
This is the pin holding the selector forks in the gearbox.
There is a small O-ring between it and the casing, and it should be a press fit.
It's called Bellcrank pivot pin.
Posted 08 February 2022 - 09:27 PM
Bell crank pivot pin:
They do normally sit slightly proud. I’d be surprised if it’s wonky, if the gearbox generally works OK.
There is a rubber o-ring sealing it but they rarely leak - I’d want to be very sure there was a problem before changing it as it is a full gearbox strip down job.
Edited by GraemeC, 08 February 2022 - 09:28 PM.
Posted 08 February 2022 - 09:30 PM
You can tap them out and replace the seal, then tap it back in but as previously stated, it's a full gearbox strip.
Edited by floormanager, 08 February 2022 - 09:31 PM.
Posted 08 February 2022 - 09:34 PM
Oil nearly always ends up at that point being the lowest making it look like it is leaking but I have never seen one leak yet.
Posted 08 February 2022 - 09:43 PM
Posted 08 February 2022 - 11:15 PM
I get a few drops of oil there too. check out the drive flange oil seal where the pot joint goes in just above it. My next job is to replace that seal.
Posted 11 February 2022 - 12:04 AM
Neil, Did you find the leak? If so, where was it coming from?
Posted 12 February 2022 - 05:55 PM
Posted 12 February 2022 - 07:42 PM
Not yet. Waiting for when its time to change my oil. When all my oil is drained out, then I'll do it. I guess you could tilt the car up on one side and do it. Never done it before, so it will be a learning experience for me. :)
Posted 12 February 2022 - 08:51 PM
Posted 15 February 2022 - 02:28 PM
if not leaking leave it in. went full stripdown on mine including knocking out and refitting this with new o ring and had real problems getting thing to stop leaking. i now leave in
