Gearbox Oil Pick Up O-Ring / Gasket
6 replies to this topic
#1 mad4classics
mad4classics
  • 200 posts
Posted 09 February 2022 - 12:07 PM
Come to fit engine to gearbox...
I know to leave the half moon long and overlap the gasket on top; however the oil pick o-ring hugs the outer edge of the groove and the gasket covers this when in place instead of the gasket opening being clear of the o-ring?
Is this normal or should I make the gasket opening bigger to clear the o-ring ????
Edited by mad4classics, 09 February 2022 - 12:32 PM.
#2 nicklouse
  • 18,724 posts
Posted 09 February 2022 - 12:49 PM
Looks fine to me.  Remember it is the inner surface that is really doing the sealing.
#3 mad4classics
mad4classics
  • 200 posts
Posted 09 February 2022 - 12:52 PM
I hope the photo is not making it look better than it is; sort of covers half the o ring seal - just wondered if that's normal
When I lower the engine I'm not sure I can maintain such a central position.
 I was expecting the gasket to be clear of the o-ring.
Edited by mad4classics, 09 February 2022 - 12:54 PM.
#4 GraemeC
GraemeC
  • 7,446 posts
Posted 09 February 2022 - 12:56 PM
I tend to 'stick' the block to gearbox gaskets to the block with a smear of grease - that way the dowels and the studs over the diff housing locate them.
I must admit I personally trim the gasket to the size of the O ring groove - I prefer the o ring to have full contact with the block.  Original gaskets (way back when) didn't overlap like the new ones do.
However I'm sure 99.9% of people don't and I can't recall ever hearing of an issue.
Edited by GraemeC, 09 February 2022 - 12:57 PM.
#5 mad4classics
mad4classics
  • 200 posts
Posted 09 February 2022 - 01:03 PM
.I prefer the o ring to have full contact with the block.  Original gaskets (way back when) didn't overlap like the new ones do.
That was my thinking to - FULL contact with the block!
Is another way to position the gasket first and push the o-ring into it's groove so that the gasket is tucked down around the edge of the o ring outer edge ??? Or shall I just trim it back.
The holes for the dowels are well clear - the won't position the gasket; stud holes are snug.
Do you just grease these gaskets?
Edited by mad4classics, 09 February 2022 - 01:28 PM.
#6 GraemeC
GraemeC
  • 7,446 posts
Posted 09 February 2022 - 01:44 PM
I think putting the gasket in place first will be harder - they're not really soft/thin enough for you to push the o-ring on top.
As said - most people just assemble and have no issue.
I grease all gaskets apart from the headgasket and any that may have a sealant applied to them at the factory (like the genuine timing cover gaskets).
#7 mad4classics
mad4classics
  • 200 posts
Posted 09 February 2022 - 01:58 PM
OK, I'll trim the gasket - Thanks
I think this is a combination of poor gasket cut and slightly oversize o-ring all supplied as part of same kit. Just dug out an o-ring from an older gasket set and it's smaller - sits central to the round groove. But the one shown here hugs the outer edge tightly; I have to push the new one in whereas the older one just drops in.
Edited by mad4classics, 09 February 2022 - 03:28 PM.
