Master Cylinder Types
16 replies to this topic
#1 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 12 February 2022 - 05:05 PM
I've read about different type of master cylinders but as the search doesn't appear to work I was wondering what a "Black Tag" master was .. I believe it is off a 92-96 Rover Metro/100(?) and so far it seems to be a split system type.
It's vertically mounted over the servo which lays horizontally over the pedals.
Just checking that is correct?
Does anyone have a list of the different types available?
Edited by gazza82, 14 February 2022 - 01:54 PM.
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 12 February 2022 - 05:13 PM
No, a black tag is a late 70s early 80s cylinder that is now NLA.
For a 92 to 96 you need the green tag master cylinder with the servo that mounts directly to the MC.
Minispares.com
click parts manuals
Click braking systems
Click master cylinders
Edited by cal844, 12 February 2022 - 05:18 PM.
#3 nicklouse
  • 18,998 posts
Posted 12 February 2022 - 07:01 PM
A black tag.
HngJ2d9.jpg[/size]
Edited by nicklouse, 12 February 2022 - 08:45 PM.
#4 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 12 February 2022 - 08:39 PM
Different type of black tag ...
#5 Spider
  • 15,684 posts
Posted 13 February 2022 - 05:51 AM
There was also a Vertical Tandem Black Tag. These were the same as the Green Tag Tandem cylinders, except they had imperial threads.
#6 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 13 February 2022 - 09:57 AM
So it looks like this is a tandem/split circuit master with metric threads .. that will work with the way I'm thinking .. just need to find the pressure limiters at less than £140 each!!
#7 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 13 February 2022 - 03:54 PM
Do away with the FAMwtf valve and fit an inertia valve at the rear
#8 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 13 February 2022 - 11:47 PM
If this is a Metro cylinder it appears to need two .. it's a split-system one outlet feeding RH front and LH rear, and the other outlet feeding LH front and RH rear. There is a valve in each side feeding rears.
#9 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 13 February 2022 - 11:50 PM
Now I know what I'm looking at this is the pipework schematic I probably need to replicate ..
Attached File  GRID000423_copy_265x337.jpg   42.7K   1 downloads
#10 nicklouse
  • 18,998 posts
Posted 14 February 2022 - 12:00 AM
Errrm the Metro MC is nothing like the Mini set up. Mount differently for a start. And are a totally different split system.
you dont seem to be telling all the info. We are presuming one thing but you seem to be talking about something totally different.
#11 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 14 February 2022 - 01:54 PM
Read my first post .. I stated there it was off a Rover 92-96 .. and I know it is nothing like a Mini which is why I was looking for advise/help.
It is destined for "Bitza", the Austin A35, so a hybrid system will not be a problem .. I'm just trying to decide which system to go with before I start to cut large holes where there aren't any. I've got a non-servo'd Mini pedal box, the Rover/Metro black tag/servo but with a cable clutch which is not what I want/need and another from another Metro that could have a hydraulic clutch (the bulkhead plate has the right holes/studs but came off an auto so is missing a vital pedal!).
At the moment my shell has nothing attached but will have discs up front and drums at the rear. What I didn't want to do is design the pipework for the wrong type of master cylinder. As usual the more modern Haynes manuals also only have have the info. Not one mention of the pipework layout or it would have been obvious.
I'm planning a day out at the Classic Car and Restoration Show next month so I'll try and find a few Metros there to look at and ask questions!
#12 Spider
  • 15,684 posts
Posted 14 February 2022 - 07:11 PM
Just remember to also take in to account the pedal ratio as well as the Master Cylinder Bore Size here too.
#13 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 14 February 2022 - 11:00 PM
I'm waiting for my "Go-to" man to return to the world .. he's isolating from this bl**dy Omicron .. then I'll be able to push on .. he's already used these masters in an A35 saloon and van. The saloon had over 140hp so needed good brakes! (1275 turbo!)
#14 Ethel
  • 26,580 posts
Posted 15 February 2022 - 12:06 PM
What brakes/calipers do you have?
That was plumbed in as a diagonal split. Earlier Metros, with 4 pot calipers, had a conventional 4 wheel circuit, with an extra circuit doing 1 pot each side up front.
A front/rear split with an inertia valve limiter, or FAM7821, would be ok.
#15 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 15 February 2022 - 02:23 PM
At the moment I'm working with 7" Midget single pot calipers/discs, but I am looking at some more powerful and larger discs from Frontline Developments ... just need to sell a kidney!
Yes, seen that 4-pot setup .. the lower outlet seems to feed all the brakes in the normal way then the upper outlet to the second hose on each caliper.
