Steering Rack - Can The Seal Be Retro-Fitted?
#16
Posted 17 February 2022 - 09:23 PM
#17
Posted 18 February 2022 - 07:45 PM
To me they are just something else to wear out. If the rack is correctly fitted and the U-bolts properly tightened, with Nyloc nuts used, then the rack is secured and located.
I'm sure some will say that the strips are vital, but I have not found that to be the case.
Yes it seems an odd item to have on a u-bolt. Seems like a compromise for a poor/loose fit between u-bolt and rack. Cheaper to fit this bodge than change the steering rack casing cross section to make it a proper fit to u-bolts.
#18
Posted 18 February 2022 - 08:39 PM
Our local production never used these strips. When they changed to a locally made Steering Rack (1965-ish), they did fit steel plates, they are about 5/32" thick, pressed, but not really shaped to the Rack Body. I know when these aren't fitted, the Rack can slip in the body but the main reason I think they fitted them was to 'correct' the front end geometry in regards to bump steer, not that these correct it completely, but I can usually feel when they haven't been fitted as the bump steer is very much noticeable.
#19
Posted 18 February 2022 - 10:22 PM
What do you mean by bump steer? Just the movement of the steering wheel when hitting a bump? Can't understand how thin strips of plastic could affect something like that... .
#20
Posted 19 February 2022 - 06:27 AM
You may wish to google the term to get a full description, but basically as the suspension rises and falls, the car should but doesn't steer straight or maintain the same line when cornering.
