Rear Fog Light Fuse Location
Posted 15 February 2022 - 09:46 PM
Any suggestions much appreciated, thank you!
Posted 16 February 2022 - 12:38 AM
If you use the link below and scroll down you will find instruments for spi 92-96 and fog lamp circuits.
The fuse for rear should be one of the line fuses in the engine bay blue to blue orange with 10a
https://www.theminif...agrams-redrawn/
Edited by hulsmeier, 16 February 2022 - 12:39 AM.
Posted 16 February 2022 - 07:26 AM
Posted 16 February 2022 - 09:13 AM
I noticed the discrepancy with the wire colours at least you have a place to start with the fuse hopefully that sorts you out
Posted 16 February 2022 - 11:54 AM
I have continual problems with that inline fuse and just pulling apart and reseating cures it until the next time. I think those inline fuses are subject to a lot of vibration especially if you've removed the factory fitted sponge sound insulation.
I've attach a pdf with info on the fuses and that applies 92 - 96 minis.
The offending fuse has a blue/orange wire.
Edited by MikeRotherham, 16 February 2022 - 12:01 PM.
Posted 16 February 2022 - 12:24 PM
I think that switch will have a tell tale lamp in it to show it is on, so the black will be the earth for that.
The blue/orange is the power into the switch from the fuse, the blue/yellow is the feed out of the switch to the foglamp. It sounds like you are missing the power feed - maybe the wire has got pulled out of the connector?
Posted 16 February 2022 - 12:52 PM
I noticed the same when doing continuity tests on my loom
in the end i cut it out, soldered straight through, and wired it back to a spare way on a new larger fusebox (blade type). I suppose you could also just replace the inline fuse holder for a more modern fresh one with tighter connections
Edited by stuart bowes, 16 February 2022 - 12:53 PM.
Posted 16 February 2022 - 04:04 PM
I am considering adapting a Wired by Wilson fusebox and replacing all the inline fuses at this location with that.
Posted 16 February 2022 - 04:58 PM
Edited by hulsmeier, 16 February 2022 - 04:59 PM.
Posted 17 February 2022 - 04:27 PM
A '95 Spi should have 24 way fuse box and no inline fuses. Fuse no. 24. Its common for the fuse to blow if water was gotten into the fog light.
You will find the relevant diagrams in the first post below the lists.
Edited by viz139, 17 February 2022 - 04:30 PM.
Posted 24 February 2022 - 06:24 PM
