Help Identifying Brake Calipers
4 replies to this topic
#1 Bombidil
Bombidil
  • 21 posts
Posted 21 February 2022 - 10:03 PM
Hi all,
I bought these calipers on eBay, before really knowing enough about the Metro conversion. I'll be at a stage where I'll be building the subframe up and putting brakes on soon, and just got round to getting these out of the shed. I don't think they are the turbo brakes, as the advert says non vented (my mistake being a noob). They are 4 pot APs.
I live around the corner from Big Red Brakes and was going to get them restored. Question is, should I bother, and can I use them, if they aren't the Turbo ones?
#2 nicklouse
  • 18,622 posts
Posted 21 February 2022 - 10:37 PM
They are just early Metro solid disc brakes. Perfect to use. Vented discs just don’t get up to temp.
all metros later on have vented discs.
do a dry build of your brakes before you send them for a rebuild to check you have all the bits you need and they work together.
#3 viz139
viz139
  • 672 posts
  • Local Club: Irish Mini Owners Club
Posted 22 February 2022 - 05:53 PM
Perfectly good caliper to use, vented would be better for a track car, vented also pushes the wheel out further. You will require these bolts to mount the calipers.
http://www.minispare...ic/ERA1128.aspx
#4 nicklouse
  • 18,622 posts
Posted 22 February 2022 - 09:57 PM
Sorry vented don’t always push out the wheels more. But yes they can.
#5 Ethel
  • 25,988 posts
Posted 22 February 2022 - 10:15 PM
They should be a direct replacement, but they have metric fittings, hence the bolts Viz linked & you can get hose conversion kits. The bleed screws are on the small side though with a tendency to shear, so replace them as a minimum. If you have a build up also slip your wheels on, there's the odd one that has clearance issues.
