Mpi Expansion Tank Cap Blowing Off Again!
16 replies to this topic
#1 Rusty Nut
Rusty Nut
  • 21 posts
Posted 03 March 2022 - 11:25 AM
Good morning all
2001 MPI - and it keeps overheating in traffic. Expansion caps are rubbish and even after two changes, its still doing it. The trouble seems to be that the PO must have overtightened the cap to compensate so the thread doesn't hold any more so of course its going to blow off (sorry!)
I've flushed the system, changed the thermostat and sensor and the fan collector.
All are working properly - opening or coming on at the right time -  but the system is just not holding the pressure so boils over.
So if I buy a new regular expansion tank will it just do the same?
Or get a steel one made?
Or a roll of PTFE tape?
Any permanent fixes for this anyone?
#2 cal844
cal844
  • 9,633 posts
  • Local Club: TFMOC
Posted 03 March 2022 - 11:37 AM
Get an alloy one made, you can then use a better quality cap. Try flushing the radiator etc through
#3 Steve220
Steve220
  • 5,062 posts
  • Local Club: BMC
Posted 03 March 2022 - 11:43 AM
Are you using an eBay cap or a genuine BMW mini one??
#4 Quinlan minor
Quinlan minor
  • 1,201 posts
  • Local Club: LSMOC
Posted 03 March 2022 - 11:52 AM
Check your expansion tank very carefully.
This pinhole, on the side close to the wing, kept me puzzling for a while.
#5 Midas Mk1
Midas Mk1
  • 5,786 posts
  • Local Club: S.U.N.M.C
Posted 03 March 2022 - 12:59 PM
Ive got an alloy header  tank on ebay, this is the reason I went for it when I ran an MPi block.
#6 gav
gav
  • 700 posts
Posted 03 March 2022 - 04:07 PM
PCF101240ALLOY - Mini expansion tank for mpi alloy (minispares.com)
#7 Midas Mk1
Midas Mk1
  • 5,786 posts
Posted 03 March 2022 - 04:53 PM
Pm if interested, pretty sure mines from Minispares, used for about 3k. but would be under £100.
#8 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 03 March 2022 - 06:33 PM
Unlikely to be popping the pressure cap if it had a hole .. there wouldn't be enough pressure.
#9 Quinlan minor
Quinlan minor
  • 1,201 posts
  • Local Club: LSMOC
Posted 03 March 2022 - 06:54 PM
"Ye cannae change the Laws of Physics, Captain!"
The pinhole causes the drop in pressure towards atmospheric.
The drop in pressure allows the coolant to boil at a lower temperature, close to 100° Celsius.
The pressure cap is designed to hold the pressure against air/vapour, not to stop the egress of boiling liquid coolant.
QED
#10 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 03 March 2022 - 07:49 PM
It will also take the route of least resistance .. ie the rusty hole rather than try to force the pressure cap off ..
"O-Level Physics pass" when O-Levels were a thing! ;) (I hated Physics .. more specifically the Psychopath that was mascarading as a Physics teacher, but the more mechanical stuff I was interested in plus I blew up a radiator once when the seam in the header tank started to go .. that let go under pressure before the rad cap.)
#11 Quinlan minor
Quinlan minor
  • 1,201 posts
  • Local Club: LSMOC
Posted 03 March 2022 - 08:40 PM
Hydraulic pressure will always win, because liquids are incompressible. Witness what happens when there's a bubble of air in the braking system.
#12 roblightbody
roblightbody
  • 447 posts
Posted 04 March 2022 - 10:26 AM
Why would a mini need an alloy expansion tank, when every other car on the road has a plastic one? Genuine question!
#13 Quinlan minor
Quinlan minor
  • 1,201 posts
  • Local Club: LSMOC
Posted 04 March 2022 - 10:43 AM
Because the quality of the plastic ones is problematic, to say the least.
I'm now on my second new replacement in seven or eight years.
The plastic,IMO, is too thin and the welded joint is insufficient.
If you look at plastic expansion tanks in other vehicles the plastic is more than 5mm thick and the shape, more often than not, sperical.
The MPi's one is about the same thickness and shape as a brake fluid reservoir/ice cream tub, less than ideal for repeated temperature/pressure cycles.
#14 sonscar
sonscar
  • 3,031 posts
Posted 04 March 2022 - 11:28 AM
Quite a lot of other elderly vehicles with plastic tanks have them fail.Age heat cycles vibration etc all take a toll.As mentioned new stuff is of variable quality.Steve..
#15 Steve220
Steve220
  • 5,062 posts
  • Local Club: BMC
Posted 04 March 2022 - 03:49 PM
Packaging and cost.
