Straight Cut Drop Gears
15 replies to this topic
#1 merther
merther
  • 151 posts
Posted 18 March 2022 - 08:45 AM
I have sc drop gears fitted to my car. They are from mini spares. I understand drop gears make noise but mine seem excessively noisy. Like they drown out any engine noise and all I can hear inside is the gears.  They are ratio’d so not 1:1. They also rattle when in neutral. Is this normal?
#2 nicklouse
  • 18,711 posts
Posted 18 March 2022 - 09:15 AM
Normal.
#3 Gaz66
Gaz66
  • 963 posts
Posted 18 March 2022 - 10:18 AM
Welcome to the world of straight cut gears.
Its like music to my ears!
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 18 March 2022 - 10:26 AM
Welcome to the world of hearing problems in later life. I changed my straight cuts for helicals and suddenly heard lots of squeaks and rattles I didn't know existed.
#5 mini13
mini13
  • 3,811 posts
Posted 18 March 2022 - 11:52 AM
Fit a SC final drive... then you wont be able o hear the drops LOL
#6 Steve220
Steve220
  • 5,074 posts
  • Local Club: BMC
Posted 18 March 2022 - 12:25 PM
Ear plugs or headphones help :lol:
#7 Gaz66
Gaz66
  • 963 posts
Posted 18 March 2022 - 04:00 PM
https://youtu.be/dmJH84FnQa8
When your sc gearset sounds like this its time for ear defenders!
Effin nora!
#8 bpirie1000
bpirie1000
  • Area Managers
  • 2,384 posts
  • Local Club: Amoc
Posted 18 March 2022 - 05:30 PM
Effin nora!
Sounds like my wife..... some say that only dogs and cats can hear her screams when she gets to know how much i spend in mini spares.....
#9 Cooperman
  • 23,330 posts
Posted 18 March 2022 - 11:31 PM
SC drop gears are intended only for competition cars and thus crash helmets reduce the horrible noise they make.
They really are unsuitable for road cars and are not needed.
I won't even fit them to rally cars.
#10 coopertaz
coopertaz
  • 810 posts
  • Local Club: a-series-magpies
Posted 24 March 2022 - 11:16 AM
club member fitted them, not for long. straight cut box with clubman gearset all the way
#11 Cooperman
  • 23,330 posts
Posted 24 March 2022 - 03:48 PM
When I fitted my SC drops, it was after I had to retire from a rally when the helical drop gears failed. However, that was after almost 30 rallies, so I shouldn't complain really. Anyway, I fitted the SC drops, but the noise was horrible. It was not so bad during competitions when wearing crash helmets with intercom or road-section headsets, but if I wanted to simply go out and drive around to enjoy the simple driving experience, it was anything but good. In fact, I found i was reluctant to even go out in the car and I took the SC drops out and reverted to helical ones.
With SC drops, ear-plugs are a must as a minimum for road driving, unless you really do want to suffer from tinnittus in later life (as I do, and fun it ain't!).
#12 unburntfuelinthemorning
  • 1,991 posts
Posted 04 April 2022 - 09:33 PM
SC drops sound much nicer when flooring it so you just need to make sure you floor it at all times.
#13 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 05 April 2022 - 10:37 AM
The noise is the reason I went for the following: Straight cut gearbox and helical drops. You get the whine of straight cuts from 1st to 3rd then 4th gear is all helical and quiet because youre just locking input to output.
#14 OzOAP
OzOAP
  • 387 posts
Posted 05 April 2022 - 08:53 PM
I run SC drops on my road car. Many passengers have commented that its not as noisy as they thought it would be.
One reason for that, they are fitted properly.
Measure the lash between the idler and input as this is set by the gear manufacturer, then measure primary/idler lash. This can be altered by different thickness gaskets between engine and box.
There is big variation in gasket thickness from one manufacturer to another.
#15 mini13
mini13
  • 3,811 posts
Posted 06 April 2022 - 08:17 AM
on this note... if youve had the block line bored or honed, it will increase the lash, in some cases, you may have to dispence with the gasket altogether and just run sealant,
