Ecu Case 12 Volt Live!
7 replies to this topic
#1 R32Egor
R32Egor
  • 313 posts
Posted 27 March 2022 - 02:10 PM
HI all,
I have a weird what i presume is an earthing problem.
Some history -
Basically the SPI was running rich and with diagnostics it was found the Lambda sensor circuit was faulty.
Lambda sensor was changed with bosch original and the ECU was also sent away for overhaul/fix by ATC.
Everything came back but was not fully tested until today (lots of other work to do also). The car started ok and seemed to run with no problems yesterday and today was reinstalling the bonnet when there appeared to be an electrical connection between the bonnet stay and the ECU.
On checking with ignition off there was indeed +12 Volts on the ECU cover. (measured volts between the case and body). Luckily the screws that hold the ECU to the holding plate were insulated with the plastic fittings.
With ignition on this voltage drops to mv range. When switching off the ignition the voltage drops to around 0.5 volts and then after the, what i think is, the stepper motor has adjusted the volts then jump back up to 12 volts.
When the cover is grounded 1 of the relays in the MFU relay box is activated - I will let you know which one when I do some further testing today (Monday).
If i disconnect the small plug of the relay box then this removes the 12 volts when ignition is off and a mv reading when the ignition is on.
If the car is started and the diagnostics are connected the Lambda sensor does not go into closed loop (the original problem) when cold - i have not got it to temperature yet because of the ECU live case problem.
If have an MPI relay box but I think they are different - Is this correct?
Would i be correct in thinking that the relay box is suspect? even though I cannot work out how the ECU case becomes live from wiring diagrams. I have ohmed out between case and every pin on the ECU and there does not appear to be a connection.
Any help with this would be great :techsupport:
Edited by R32Egor, 28 March 2022 - 08:09 AM.
#2 R32Egor
R32Egor
  • 313 posts
Posted 27 March 2022 - 05:07 PM
Its a single connector ECU - MNE101170 with immobilizer removed (not sure how as I bought it this way)
#3 R32Egor
R32Egor
  • 313 posts
Posted 28 March 2022 - 05:55 PM
Just did some more investigation -
Main relay in MFU switches if you ground out the ECU case.
So measured pin 4 on the ECU and ohmed between case and pin 4 and am getting around 17-20 Kohms - I am presuming this is not good?????
I am sure this pin is causing problems as when the ECU earths (ignition on) pin 4 the voltage disappears and only comes back when ignition off.
Any body know anymore??
Will be ringing ATC in morning as the ECU is under warranty.
Edited by R32Egor, 28 March 2022 - 05:56 PM.
#4 sonscar
sonscar
  • 3,084 posts
Posted 28 March 2022 - 06:01 PM
The case should have no conditions on it,I would say there is a fault in it,Steve..
#5 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 29 March 2022 - 01:18 PM
Pin 28 on the ECU connector is the ground for the ECU. I would check the for continuity between the case and it and I would expect no resistance. On the loom side, there should be no resistance between pin 28 and the the earth point on the gusset by the servo.
#6 R32Egor
R32Egor
  • 313 posts
Posted 31 March 2022 - 06:39 PM
I will check this for sure.
#7 Carlos W
Carlos W
  • 10,115 posts
Posted 01 April 2022 - 01:23 PM
What have ATC said?
#8 R32Egor
R32Egor
  • 313 posts
Posted 09 April 2022 - 08:26 AM
Checked above and there was no connection between pin 28 and cover
And between pin28 and car ground no resistance
Atc said I could open the ecu and I found that the earthing pad for the cover was indeed not connected to pin 28
So because I had to drive it to the garage for other setup tests - I insulated the cover from the earthing pad(of pcb) with plastic washers and screw.
Everything good but the lambda sensor circuit goes into closed loop intermittently. But when it does my emissions are in spec👍👍👍😁😁😁😁
So at least I now know it is an ecu problem for sure.
So the ecu is now with Atc and I am hoping for a good outcome, I need the ecu back by Friday 22nd April as I have my Tüv proofing test to allow the car in Austria
So all fingers crossed 🤞🤞🤞
