Clutch Pedal Pressure
27 replies to this topic
#1 croc7
croc7
  • 813 posts
Posted 29 March 2022 - 07:50 PM
Had anyone been successful in reducing foot pressure at the clutch pedal? Maybe through the use of a larger master cylinder?
#2 sonscar
sonscar
  • 3,002 posts
Posted 29 March 2022 - 09:18 PM
Wouldn't it be smaller master cylinder(I struggle with this sometimes),Steve..
#3 croc7
croc7
  • 813 posts
Posted 29 March 2022 - 10:42 PM
Yeah, me too.  I should have phrased it as a master cylinder capable of producing higher pressure.  And if there is one, then is that higher pressure a concern regarding clutch hose, slave cylinder capabilities, etc.
#4 nicklouse
  • 18,600 posts
Posted 29 March 2022 - 11:33 PM
Let’s start at the beginning.
what is the problem you are trying to fix?
as changing piston sizes changes other parameters which may not be possible due to outside constraints.
#5 Spider
  • 14,892 posts
Posted 29 March 2022 - 11:46 PM
Hey J !
With the pre-verto (which is I'm sure what you have), when the clutch plate, flywheel and backing plate are set up correctly, they aren't too bad, a little heavier than clutches in most other cars, but by no means objectionably so.
If this is still heavier than you'd like, you can - with some small extra work - swap over the main body from a Brake Master. The extra work I'm referring to is swinging the Reservoir from the Brake to the Clutch position (the Aussie made cylinders, which are NLA were easy for this, just bolt them in 1800 around). All the other components though need to be in good order to ensure you get enough travel out of it all, but it will do it. The Clutch Master is 0.75" dia and the Brake is 0.70", so it will make it a little lighter.
Another option is probably to go to a Verto style Clutch, these have a very light pedal, but IMO, these are not a good arrangement.
#6 croc7
croc7
  • 813 posts
Posted 30 March 2022 - 12:29 AM
The problem isn't mechanical, its bio-mechanical.  My left knee isn't as young as it used to be.
#7 nicklouse
  • 18,600 posts
Posted 30 March 2022 - 08:47 AM
It still is mechanical as the system is a closed loop. With defined travel requirements. Changing the piston size will change the travel needed at the pedal if you want to keep the travel needed at the slave.
hence the question as  you could have been doing something that does not have the restraints that the current set up puts on it.
making the MC diameter smaller will reduce the force you need to apply but you will need to move the pedal further as there will be less fluid moved. IIRC most Mini clutch pedal hit the floor anyway. So there is a good chance that you will not disengage the clutch,
which set up is it! And is the pressure plate standard?
#8 panky
panky
  • 1,791 posts
Posted 30 March 2022 - 10:17 AM
If you could find the room you could fit a brake servo to the clutch system.
#9 croc7
croc7
  • 813 posts
Posted 30 March 2022 - 09:09 PM
Its a run of the mill pre verto set up with a blue spring. Looks like I’m stuck. Thanks for the thoughts.
J
#10 Andosoft
Andosoft
  • 15 posts
  • Local Club: Nsw
Posted 31 March 2022 - 04:13 AM
Worth watching this if you haven't youtube.com/watch?v=C3c5EcpYiP8 where he goes through setting up the clutch and reducing/optimizing the pressure required to release the clutch.
Edited by Andosoft, 31 March 2022 - 04:16 AM.
#11 nicklouse
  • 18,600 posts
Posted 31 March 2022 - 06:37 AM
IIRC the Verto clutch has a lighter pedal. Not sure but I am sure others know.
I remember my metro pedal being light.
#12 mini13
mini13
  • 3,810 posts
Posted 31 March 2022 - 07:45 AM
Ok, I know a bit about this,
First off, I think modding the pre-verto setup is probably a no go, as there is not a lot of spare travel, in fact any wear/mis-adjustment can cause issues in that setup anyway.
on the verto setup I have successfully lengthened the arm on the wok by roughly 1/3 to get a lighter pedal (this is on an RTS clutch with two springs stacked for a turbo motor)
there is a third option, I have heard of people fitting the remote servo as used on cooper's in the clutch line, its supposed to work well, but takes up a fair bit of room.
https://www.moss-eur...-servo-kit.html
#13 Ethel
  • 25,951 posts
Posted 01 April 2022 - 11:13 AM
Metros had a 5/8" master compared to  3/4" on a Mini. I've used one with a Pre-Verto & pre '76 pedal box.
#14 stuart bowes
stuart bowes
  • 2,124 posts
Posted 01 April 2022 - 12:28 PM
is it not possible to just make the pedal longer with a bit of creative cutting and welding (or just bolting on an extension)
maybe an extra inch or two would help just with the basic added leverage
#15 coopertaz
coopertaz
  • 796 posts
  • Local Club: a-series-magpies
Posted 01 April 2022 - 01:24 PM
easiest step to go to verto, but get a lightened unit as, in my experience, these have a tendancy to move on crank under heavy use. from memory didn't metro also have a small cylinder inline with slave? never used it threw in bin with mounts.
