Stupid Supercharger Idea
15 replies to this topic
#1 Project84
Project84
    Just On Tickover
  • 8 posts
Posted 01 April 2022 - 10:02 AM
Stupid idea #378
Would this work?
1. Air Filter
2. Webber Downdrafts
3. Supercharger
4. Intake from the supercharger into the back of the inlet manifold
5. One-way valve to dump excess pressure back into the inlet (or atmospheric)
Edited by Project84, 01 April 2022 - 10:03 AM.
#2 whistler
whistler
  • 1,818 posts
Posted 01 April 2022 - 10:14 AM
I know nothing about superchargers but to my eyes it looks as though the supercharged air will go up through the carbs and to atmosphere as well as into the head.
#3 stuart bowes
stuart bowes
  • 2,232 posts
Posted 01 April 2022 - 11:58 AM
presumably you mean point 4 going into the top (in) side of the carbs and point 2 is the lower (out) side of the carbs, into the head
definitely no expertise here either just pointing out the diagram is a bit unclear
#4 coopertaz
coopertaz
  • 806 posts
  • Local Club: a-series-magpies
Posted 01 April 2022 - 01:10 PM
would blow back out of the carb inlet, supercharger needs to draw through carb. have seen it done with weber over clutch housing and supercharger at rear of engine, already a kit in common use for su in this format.
#5 Carlos W
Carlos W
  • 10,114 posts
Posted 01 April 2022 - 01:11 PM
I think it'll run horrifically lean
#6 coopertaz
coopertaz
  • 806 posts
Posted 01 April 2022 - 01:13 PM
wont run at all just spray fuel onto underside of bonnet
#7 IronmanG
IronmanG
  • 1,253 posts
  • Local Club: Box hill. Lsmoc member
Posted 01 April 2022 - 02:22 PM
Car kitchen is just setting up something like that with SC at the front of the bay
#8 IronmanG
IronmanG
  • 1,253 posts
Posted 01 April 2022 - 02:24 PM
Attached File  Screenshot_20220401-152405_Facebook.jpg   38.42K   18 downloads
#9 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 01 April 2022 - 04:05 PM
Don't quote me, but i'm sure webers don't like boost THROUGH them.. as it gets very complicated.
#10 coopertaz
coopertaz
  • 806 posts
Posted 04 April 2022 - 04:02 PM
 is he also using webber? interested to see if using it before or after supercharger
#11 coopertaz
coopertaz
  • 806 posts
Posted 04 April 2022 - 04:11 PM
checking on their site, yes supercharger is at the front this is not new, but the issue here has been placing carb after supercharger. if you search can only find su or throttle bodies used as blow through, webbers have only been used as draw through. and you would need to fabricate a flange to join to webber inlet trumpets, not put above as shown in poject 84s' pics at start of this thread
#12 sonscar
sonscar
  • 3,037 posts
Posted 04 April 2022 - 04:50 PM
I dimly remember Webber's need to be in a pressurised box to equalise the float chamber pressure when blown through.Could be wrong,Steve..
#13 mini13
mini13
  • 3,811 posts
Posted 05 April 2022 - 07:10 AM
Yep when blowing through a carb you need to make the pressure in the float bowl rise as fast ( or faster) than boost. on the metro turbos's have a restrictor ring on the inlet to the carb, to make this happen. another  way is to use a pitot tube.
obviosly the float chamber needs to be sealed, and fed by boost.
#14 coopertaz
coopertaz
  • 806 posts
Posted 06 April 2022 - 11:20 AM
float chamber fuel pressure needs to be higher than boost but fed by it!!?
#15 mini13
mini13
  • 3,811 posts
Posted 06 April 2022 - 11:56 AM
ok, float chamber needs to be at boost pressure, but the jet needs to be at a lower pressure, hence the carb restrictor....
the general terminoligy is the float chamber needs to be "at boost pressure" rather than atmospheric
