Access Into Back Of Headlight 'bucket' For Additional Wiring?
electrical
6 replies to this topic
#1 lachlan1275gt
lachlan1275gt
  • 21 posts
Posted 02 April 2022 - 10:53 PM
Hi
I am installing some new headlights on my 1981 clubman that have 2 additional wires on them compared to the standard light (running light and indicator).
What is the best way of getting these additional wires INTO the headlight bucket, even if I pulled the rubber 'plug' out it doesn't look like there would be enough space for them to fit through with the current 3 wires.
See attached images to see what I mean
#2 weef
weef
  • 416 posts
Posted 03 April 2022 - 09:35 AM
i presume from your post you have a 5 wire loom fitted to the old headlight at present and the new headlight unit has only 3 wires.
If this is the case remove both looms from each headlight, compare the grommet hole sizes and adjust to suit on the new headlight bowl, if needed, and then fit the 5 wire loom to the new unit.
#3 bpirie1000
bpirie1000
  • 2,119 posts
  • Local Club: Amoc
Posted 03 April 2022 - 09:47 AM
Drill another hole. New grommit... still not sure why you are running an indicator wire into your hedlamp..
#4 KTS
KTS
  • 2,264 posts
Posted 03 April 2022 - 10:26 AM
this type of grommet (and some pvc sleeving) might work better for what you're wanting to do
https://www.autospar...eadlamp-grommet
you could also consider replacing the wires themselves with thinwall equivalents which are less bulky
#5 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 03 April 2022 - 01:03 PM
I agree, very confusing! Sidelight and indicator is different from the main light unit
#6 Alex_B
Alex_B
  • 4,573 posts
Posted 03 April 2022 - 03:28 PM
Assuming he is planning to run the LED headlight that uses the halo lamp portion as a sidelight as well as an indicator hence needing the extra wiring. But as above just fit a suitable grommet into a larger hole, add some silicone sealer if you end up with a gap to prevent water ingress.
#7 lachlan1275gt
lachlan1275gt
  • 21 posts
Posted 03 April 2022 - 10:32 PM
Correct I am using a newer led headlight which has a running light and indicator built into the unit.
Awesome thanks, I was trying to avoid doing the obvious/intrusive thing and just drilling another hole but thats fine.
