Minispares sell these magnetic oil traps below similar to the magnetic sump plug but if fitted and then neglected/forgotten/not cleaned regularly the build up of trapped metal debris can cause more problems....
MAGNETIC OIL TRAP FOR GEARBOX
"Fits in place of the oil pick up retainer plate on the back of the gearbox this magnetic plug filter collects metal debris from going back into the power unit but should be regularly cleaned. Also available as the ultimate is the same item with a built in filter gauze."
https://www.minispar...rap-for-gearbox
MAGNETIC OIL TRAP WITH FILTER
"Fits in place of the oil pick up retainer plate on the back of the gearbox this magnetic plug with filter collects metal debris from going back into the power unit but should be regularly cleaned. A non filter type of theis version is also available."
https://www.minispar...rap-with-filter
IN LINE OIL PICK UP MAGNETIC TRAP WITH FILTER – Fitting Instructions:-
https://www.minispar...og/pdf/HPS5.pdf
Quote: "It’s position in the oil supply gallery necessitates frequent removal of the trap to clean collected particles out, more so for the filtered version. Failure to do this will cause premature failure of the pump and possibly engine bearings. There are no hard and fast rules for this periodic maintenance as vehicle usage will determine debris build up. Obviously a carefully driven road car will not need as frequent attention as a race car. Certainly clean it at every oil change. This frequent servicing can be of benefit as excessive amounts of debris could indicate a deteriorating gearbox."
Edited by mab01uk, 16 July 2025 - 09:39 AM.
