Driveshaft To Pot Joint (Inner Cv) Oil Seal?
Best Answer Spider , 14 April 2022 - 06:21 PM
I've never run with them ever and can't say I've ever had a problem.
Go to the full post
2 replies to this topic
#1 Mini-Advantage
Mini-Advantage
  • 58 posts
Posted 14 April 2022 - 11:10 AM
Hi all,
I'm replacing my pot joints (inner CV) and just looking at the Minispares website it says that there is an inner oil seal that was fitted to cars upto 1994.
http://www.minispare...ck to catalogue
As it was discontinued by Rover in 1994 is it still needed?
(I have a 1987 Mini Advantage)
#2 coopertaz
coopertaz
  • 907 posts
  • Local Club: a-series-magpies
Posted 14 April 2022 - 04:18 PM
when you remove shaft from pot joint if the seal is there it normally is split, don't need it just smear anti sieze paste on splines, this will help stop the rusting there. dont forget good idea to change output shaft oil seals same time as pot joints. can pull them out with small driver and tap back in with deep socket
#3 Spider
  • 15,684 posts
Posted 14 April 2022 - 06:21 PM   Best Answer
