Weber Float Setting
2 replies to this topic
#1 Mudhen
Mudhen
  • 56 posts
Posted 15 April 2022 - 02:42 PM
I recently purchased an old rallycar with a Weber carb on it....was trying to set the float but ran into an issue.  The top cover says it's a 45DCOE Series 13 - the Haynes Weber book doesn't list any spec for that.  Also, if I measure the throat of the carb it measures 48mm - so is it really a 48DCOE?  The book doesn't list a single 48 spec...
Thanks,
Pat
#2 r.tec
r.tec
  • 216 posts
  • Local Club: SfG Schoenau
Posted 15 April 2022 - 04:30 PM
http://www.baukasten...ni_cooper_s.pdf
#3 Mudhen
Mudhen
  • 56 posts
Posted 15 April 2022 - 06:10 PM
Thanks!
Mine was around 3mm when closed so off by a good bit!
Pat
