Hi guys,
Just put a set of new rockers together (C-AHT436) and I am finding the surface of the pedestal has a milled finished and is making the rocker "notchy" against the fine grooves. Is this normal?
I am thinking of putting .40 thou spacer washers (AEG168) in between the rocker and pedestal, but it seems odd that I will have to put in 8 washers to fix the problem.
I have attached pictures below, hopefully it shows the grooves on the pedestal.
Edited by Nootnoot11, 16 April 2022 - 08:52 AM.
