Cracked Engine Subframe, Replace Or Repair?
12 replies to this topic
#1 Evercloud
Evercloud
  • Validating
  • 19 posts
Posted 21 April 2022 - 05:19 PM
Hey there,
I kindly need your advice. :-)
I recently bought my Mini Cooper SPI and it has a cracked front subframe...
The previous owner gave me a spare subframe but, to closer inspection, it turned out it has been badly repaired, so now I have to figure out if finding another intact subframe or repair the original one.
My question is: is this crack a common issue, making a well repaired (maybe strengthened) subframe preferable or it is uncommon, making an intact subframe the best choice?
By the way, the engine has been rebuilt a couple of years ago so I will not be replacing the clutch but I would appreciate any suggestions on what to do as the engine has been lowered :-)
the crack:
current situation, with a circle showing the crack position:
Edited by Evercloud, 21 April 2022 - 05:20 PM.
#2 nicklouse
  • 18,697 posts
Posted 21 April 2022 - 06:43 PM
Common place for them to go if the top steady is not looked after.
it is fixable but I would check local regs because to do it right it will be noticeable to anyone looking.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 21 April 2022 - 08:03 PM
Due to your location and probably not able to access another decent subframe I would look at welding that. It looks fairly clean so should weld up well.
I have welded these before in similar locations and had no issues with them after. Welded from both sides, fully knocked back flush then painted.
#4 Evercloud
Evercloud
  • Validating
  • 19 posts
Posted 21 April 2022 - 08:28 PM
Thank you for your answer! With "local regs" you mean somebody who does this on a regular basis?
Can you please tell me something more about the top steady? I am going to replace engine mounts and many bushes but I totally forgot this part.... would you mind pointing me toward the right spare codes?
I am attaching a picture, if you can :-)
*edit: I forgot to say it is a LHD mini as I am in Italy*
Thanks for your answer to you too!
Ok!! As you both agree on that, I will go for the repair. I love the idea of keeping the original part.   :-)
Edited by Evercloud, 22 April 2022 - 08:45 AM.
#5 mab01uk
mab01uk
  • 12,538 posts
Posted 22 April 2022 - 09:17 AM
Local Regs usually means what does the Italian equivalent of the annual UK 'MOT Test' require or allow as a safe/approved repair. Regs may vary from different countries.
Minispares
Engine | Stabilisers mounts | Stabilisers:-
http://www.minispare...ers.aspx?100201
Edited by mab01uk, 22 April 2022 - 09:21 AM.
#6 Evercloud
Evercloud
  • Validating
  • 19 posts
Posted 22 April 2022 - 10:36 AM
Minispares
Ohh, I see. That makes perfect sense. Ok, I'll look into it, thanks.
About the engine stabilisers, I am ordering the steady bar bushes toghether with all the engine and subframe bushes and mounts, but thanks to you I am now considering an engine stabilitzer like MSSK1302 too.
I will keep you updated! In the meantime many thanks to all of you.
#7 R32Egor
R32Egor
  • 313 posts
Posted 27 April 2022 - 12:27 PM
Wow - I have an SPI mini I purchased in Italy (Venice area) and the subframe has been repaired in exactly the same place (before I purchased it) maybe its a LHD thing as well.
I have a knock whenever I engage the clutch but have been unable to locate the problem as of yet - the top and bottom stabilisers look ok - going to get a gopro setup to see whats moving.
Anyway it looks like welding it up is no big deal in Italy and it also passed the safety inspection here in Austria.
#8 Evercloud
Evercloud
  • Validating
  • 19 posts
Posted 27 April 2022 - 05:47 PM
Hey, thank you for sharing your experience. How did you know it was repaired?
I collected the subframe yesterday and I am happy with the result, it will take a little bit of polish and paint but it's ok, then I think no external inspection will be able to say it is repaired.
Internally it is a whole different story as I asked the guy to put a metal plate to strengthen it... it is a bit ugly but I want it to never break again. Feel free to give a feedback :-)
#9 nicklouse
  • 18,697 posts
Posted 27 April 2022 - 06:17 PM
Not a LHD thing it is a thing with that lower mount when the upper mount is not looked after.
#10 brivinci
brivinci
  • 1,210 posts
Posted 27 April 2022 - 08:04 PM
Yes, very common. As Nick said, usually caused by a bad upper stabilizer. I noticed a small crack forming on my subframe at the lower stabilizer bracket. I checked my upper and it looked perfect, and the bushes were newer. I had to REALLY get int there and noticed that the upper stabilizer bracket had sheared right at the bend and you would not noticed it by just looking. I had to stick my head in there with a good light and rock my engine to see. I batched up the subframe and bolted in a super heavy duty, SS bracket sold here in the US for just this issue. This saved me from having to weld the firewall and is extremely robust. I had the engine out while installing it as well. Nothing easy about it as its all a tight fit with a Mini
Edited by brivinci, 27 April 2022 - 08:08 PM.
#11 Evercloud
Evercloud
  • Validating
  • 19 posts
Posted 27 April 2022 - 08:59 PM
very interesting! May I ask you to post a picture of this solution? That would surely help us too! :)
#12 brivinci
brivinci
  • 1,210 posts
Posted 28 April 2022 - 02:04 AM
Here is the bracket. I fabbed up a plate with captured nuts to both ease in installation and help spread the load a bit. Powdered coated it black keep it low key. I’ll try and find pix of it installed.
Edited by brivinci, 28 April 2022 - 02:10 AM.
#13 R32Egor
R32Egor
  • 313 posts
Posted 29 April 2022 - 09:36 AM
HI,
I can see the place it has been welded as I can see the weld - Obviously the job was not as good as yours :(
