Air Filter Box
Posted 01 May 2022 - 10:04 AM
Posted 01 May 2022 - 10:09 AM
As long as the elbow fits. I've gone the other way on my Minor with a HIF airbox on a HS4
Posted 01 May 2022 - 10:15 AM
Posted 01 May 2022 - 10:57 AM
I had that box on the Mini but went back to the standard set up with a K&N element and didn't notice any difference in performance but a lot less induction noise. I've since gaffer taped half of the holes up to keep the noise down.
Edited by panky, 01 May 2022 - 11:00 AM.
Posted 01 May 2022 - 11:13 AM
Posted 01 May 2022 - 01:40 PM
It should do. I went from the cone to the drilled air box then back to the original mainstream Cooper set up - bliss
Edited by panky, 02 May 2022 - 09:35 AM.
Posted 02 May 2022 - 01:41 AM
Drilled the extran holes and have a K&N inside.
The housing works just fine on the HIF
Posted 03 May 2022 - 05:09 AM
Posted 03 May 2022 - 09:53 AM
The 44 elbow fitted my HS4 so all should be good the other way round - hopefully
I've got a spare 44 so if I get a chance I'll check later.
Edited by panky, 03 May 2022 - 09:54 AM.
Posted 03 May 2022 - 03:14 PM
OK I've got myself mixed up. The elbows are different on the carb side but either elbow will fit the air box so the standard air box can be used on either the 44 or the HS4 elbow. So the answer to you original question is yes but you need the elbow to suit the carb you're using.
Posted 03 May 2022 - 03:19 PM
drilled air box much better if wanting standard look, like you say massive reduction in cabin noise
Posted 03 May 2022 - 06:21 PM
One of my mates drilled my airbox years ago when I had a mk4 ford escort (1.3) it made literally no difference to performance but the induction noise was lovely
Posted 03 May 2022 - 06:55 PM
Posted 03 May 2022 - 07:02 PM
Ive got a 38 airbox on ebay, 44 airboxs more sort after, sold both of mine (had the snorkel too), go for seriously strong money nowadays.
You'll miss the induction noise.
Posted 03 May 2022 - 08:04 PM
I'm not bothered about the induction noise, just going for the original look, you know me, I have daft ideas lol. Centre pipe is on its wayIve got a 38 airbox on ebay, 44 airboxs more sort after, sold both of mine (had the snorkel too), go for seriously strong money nowadays.
