Oil Pressure Switch Not Working - Mot Failure?
10 replies to this topic
#1 Mini-Advantage
Mini-Advantage
  • 53 posts
Posted 02 May 2022 - 09:02 AM
Simple question from me Today. I have found out that my oil pressure switch isn't working, so have purchased a replacement.
Would this be an MOT failure?
#2 imack
imack
  • 2,203 posts
Posted 02 May 2022 - 09:03 AM
No
#3 nicklouse
  • 18,696 posts
Posted 02 May 2022 - 09:06 AM
If a warning lamp fails to illuminate or fails to go out I thought that was a failure?
#4 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 02 May 2022 - 09:12 AM
I think the "new" UK MOT rules are a bit vague, certainlig on modern cars, the Engine Management Light (EML on will be a failure as will
  • Electronic stability control
  • Safety restraint systems so seatbelts
  • Anti-lock braking systems
  • Tyre pressure monitoring sensors
but, my local MOT station now has a rule that any dashboard light that is on, and should not be on, will be a failure.
Thats probably harsh and the "wrong" interpretation of the rules, but lots of MOT "faults" are down to the mechanics discretion, and remember the mechanic has the licence, not the garage, so its very much open to his / her interpretation.
I also know mechanics who will view a light on that shouldnt be on, as an owner that cant be bothered to look after his car, so that makes him look even harder for "other" faults. Its a bit like presenting a dirty car for an MOT. If you cant be bothered to wash it, have you bothered to maintain it,, is his view.
Also  at £50 or so a go, I would fix the "fault" first just to cover my own a....
#5 Shaun78
Shaun78
  • 54 posts
Posted 02 May 2022 - 12:30 PM
Oil light going out is not a fail,but if you don't tell the tester it has a faulty switch they may refuse to test so they don't damage the car.
#6 rash
rash
    Starting My Mini Up
  • 3 posts
Posted 02 May 2022 - 03:29 PM
not a fail im a tester
#7 imack
imack
  • 2,203 posts
Posted 02 May 2022 - 03:42 PM
It might be if it's a testable warning warning lamp, but not all warning lamps are testable items.
#8 weef
weef
  • 506 posts
Posted 02 May 2022 - 05:58 PM
This is not an MOT fail but maybe a reason for a Refusal to Test in which case the individual tester should issue a CT30 giving the reasons.
But why not fix it ?.
#9 coopertaz
coopertaz
  • 807 posts
  • Local Club: a-series-magpies
Posted 03 May 2022 - 02:40 PM
test only covers safety or emission control items. question is would you want to run with lamp on? unless you have a gauge also in which case diconnect the sensor!
#10 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 03 May 2022 - 03:38 PM
A new sensor is less that £15 from my local parts place, change the sensor and verify the actual pressure of the motor....
#11 Mini-Advantage
Mini-Advantage
  • 53 posts
Posted 04 May 2022 - 06:58 PM
MOT passed with the oil pressure light not working. Thank you for all your replies 😁
The new switch arrives tomorrow so will fit it at the weekend.
Edited by Mini-Advantage, 04 May 2022 - 07:01 PM.
