What Diff For My 998
2 replies to this topic
#1 Willpill20
Willpill20
  • 61 posts
Posted 03 May 2022 - 03:11 PM
Hi , I am so close to finishing my gearbox and bolting it to the block , I just need to fit a diff and set the end float for the idler gear . What I am asking is what diff should I get ? It is a 998 with plus 60 thou pistons evo1 cam 12g295 head with 33mm inlet and 27mm exhaust valves and will have twin su carbs . I did want a cross pin diff but they are just so expensive and out of stock everywhere at the moment. Would a normal diff with the better diff pin be ok ? It is only for a road engine anyway so I would of thought it would be ok but I’m asking you guys what you think as I’m not totally sure
Hope you can help
#2 coopertaz
coopertaz
  • 938 posts
  • Local Club: a-series-magpies
Posted 03 May 2022 - 03:16 PM
yes uprated pin and new thrust washers will be fine have used these on 1340 for road still ok miles later when uprated to 4pin, for diff 3.44 good all rounder and suits 998 torque
#3 Willpill20
Willpill20
  • 61 posts
Posted 03 May 2022 - 03:21 PM
Yes 3.44 is what I have
