Quick Cam Question
4 replies to this topic
#1 Austin mini 30
Austin mini 30
  • 332 posts
Posted 12 May 2022 - 05:17 PM
Hi all,
Currently rebuilding my 1275 A+ engine. It had a standard drive slot cam in it, I’ve been offered a good kent 276 spider drive cam for the rebuild.
I assume that spider drive and slot drive cams are interchangeable? Obviously with the correct oil pump. Is this true?
Cheers!
Angus
#2 nicklouse
  • 18,998 posts
Posted 12 May 2022 - 05:44 PM
Yes they are. There are sports with slots in to use the slot drive pumps as well.
#3 ac427
ac427
  • 733 posts
Posted 12 May 2022 - 05:48 PM
Be sure to check the new oil pump clearances.
#4 Spider
  • 15,684 posts
Posted 12 May 2022 - 08:18 PM
Just check you can get a Spyder that goes in the end of the Cam to Drive the Pump, these have been NLA for a very long time now. There's other non-standard adaptors for slot drive pumps but I'm not crazy about them.
#5 Cheeser
Cheeser
  • 43 posts
Posted 13 May 2022 - 07:34 AM
Is worth mentioning that a lot of people, including me, don’ consider the 276 to be the best of cams especially when compared to some more modern cams.
