During a spirited drive yesterday, the engine lost power and cut out, luckily, I was able to pull into a safe place and park up. investigation at the roadside showed no spark at the plugs. The car is fitted with an accuspark electronic ignition module, accuspark coil (ballasted) and plugs. its a 45D dizzy on a 1380A+. It has had a slight misfire on a steady throttle which goes when under load to accelerate which I thought was a carburation/timing issue which i have been chasing to resolve (hence the road test).
SO! is here a way of checking if the coil or ignition module has failed? has anyone else had one of these suddenly let go? I bought it about 2 years ago, so i expect its not under warranty.
But then.......I had to get the car recovered, during which the exhaust snagged on the wagon, pulling it off and disturbing the - rod change gear linkage; its now in gear but the lever does nothing! (AAARGGHH) so later today I'm hoping that linkage reattachment will be a simple thing (I had a brief look last night and everything seems attached under there which worries me a little- i can't see the linkages detached at the gearbox and today will remove what looks like an inspection plate below the car in the gearstick area).
any useful tips or advice would be appreciated on either topic.
PS: I only installed the electronic ignition to improve the bloody reliability!!
