Yokohama 145 X10 Views
Posted 20 May 2022 - 06:49 PM
Shooter
Posted 20 May 2022 - 09:44 PM
Posted 21 May 2022 - 08:22 AM
I`m also interested in the 145 Yokos but I would like to know how they perform rather than how they look on the car.
I feel 165`s do roll around on a 4.5" rim and you loose a bit of sharpness in the steering and without arches they can stick out a bit otherwise I would just be sticking to A008`s.
There are some views on the 145 Blockley tyres on the MK1 forum
http://mk1-forum.net...php?f=5&t=34555
It would be nice to know if the 145 Yoko`s share the same compound as the 165`s
Or just feedback from somebody who gives their car a good thrashing :)
Blockleys are looking good for a 145 but are the Yoko`s better ?
Posted 21 May 2022 - 03:38 PM
I use 165/70 x 10 on 4.5" Minilites on my 1964 'S' which has c.100 bhp and on tarmac rallies it is great. On my 1990 Cooper 1330 road-rally car I have 5" x 10" BWA alloys and use the 165 Yoko 008's. Again, it works fine. Neither car has wheel arch extensions and I have no problems with the wheels sticking out. Remember, the original optional 4.5" wheels for the Cooper 'S' were not fitted with arch extensions.
With a 145 tyre, I have found that handling, especially in the wet, may be improved, but at the expense of best road-holding. I drove an MPI a while back on 145 x 12 Falkens, and it felt just like an early car on 145 x 10. It did not have the grip of a modern 165/70 x 10, but the response and handling were very predictable. It felt very safe, but did not go around corners so quickly. If you feel that a 165 'rolls around' on a 4.5 rim, it might be that your are not running sufficient pressure. I run at 32 psi all round.
From what I have heard, the Blockley SP3 replicas provide 1960's feel.
Maybe most people who drive a classic car do want to have the driving experience which would have existed when the car was new.
Posted 21 May 2022 - 05:49 PM
Thanks Cooperman, I'm running 28 psi so I`ll give that a go.
The 165`s are a lot cheaper to buy as well :)
