Does This Need Cleaning? Is There An Issue?
mattpurves1990
, May 22 2022 08:58 PM
7 replies to this topic
Posted 22 May 2022 - 08:58 PM
Posted 22 May 2022 - 09:05 PM
Looks like it has not been run for years.
I would wonder what the rest of the engine looks like.
cleaning anything without removing the head means the crud just goes into the engine to cause problems.
Posted 22 May 2022 - 10:57 PM
I would be very suspect if the rockers were rusty and as nicklouse said the head needs to be removed to check the bores and clean the head.
Allan
Allan
Posted 23 May 2022 - 08:05 AM
Are the rockers all free and moving sufficiently?
Does the oil look thick and black?
Alittle time spent now will save a lot of time later-maybe even stuck road side...
Posted 23 May 2022 - 10:56 AM
The car runs great. Idles good ect. Only issue I have is over 55mph the car doesn’t like it
Posted 23 May 2022 - 01:13 PM
Hold on..... you get to 55mph..... well done.....
I would suggest your issues maybe with mixture or timing more than rust on the rockers...
Posted 23 May 2022 - 04:45 PM
I agree, I have been fault finding on other issues via Facebook messenger. My advice was to try to fix the mixture with a reprofiled needle etc and run it... Happy to be corrected on that thoughHold on..... you get to 55mph..... well done.....
Edited by cal844, 23 May 2022 - 04:46 PM.
Posted 24 May 2022 - 07:59 PM
Thanks to both of you on the advice.
I’m confident the timing is out on it. I just have no idea how to check it.
I’m thinking you need specialist equipment no?
Going to get AC Todd to come and and try and sort it I think.
