Pictures Of The Rear Part Of The Spi/mpi Fuel Lines
9 replies to this topic
#1 fokko
fokko
  • 167 posts
  • Local Club: Mini Seven Club Nederland
Posted 23 May 2022 - 11:55 AM
I'm routing my own fuel lines, because I'm converting a carbed Mini to Specialist Components EFI. I'm searching some very clear pictures of the routing of the fuel lines around the rear subframe, to and from the fuel filter and in the boot to the tank. I'm trying to replicate as much as possible, so anything is helpful. I have been searching through the forum and found some pictures of the blue MPI Ben_O has restored, but it gives not enough detail of the routing...
Does anyone have a set of pictures? Preferably of a new/OEM installation?
#2 sonscar
sonscar
  • 3,085 posts
Posted 23 May 2022 - 12:17 PM
Is there a reason for replication?I would go for practical every day(I am easily satisfied though)Steve..
#3 hungdynasty
hungdynasty
  • 175 posts
Posted 23 May 2022 - 01:41 PM
Attached File  WhatsApp Image 2022-05-23 at 9.38.52 PM (1).jpeg   54.25K   10 downloads
Attached File  WhatsApp Image 2022-05-23 at 9.38.52 PM.jpeg   52.45K   7 downloads
Attached File  WhatsApp Image 2022-05-23 at 9.38.51 PM.jpeg   57.98K   5 downloads
#4 fokko
fokko
  • 167 posts
Posted 23 May 2022 - 02:11 PM
That's probably my OCD  :D , I want it to look more or less OEM... I also bought the SPI fuel filter and the lines that go with it. Only the lines front to back will be made custom (see my build thread).
Edited by fokko, 23 May 2022 - 02:14 PM.
#5 fokko
fokko
  • 167 posts
Posted 23 May 2022 - 02:13 PM
[images]
Thanks a lot  :thumbsup: ! Do you have a picture from the other side of the fuel filter? And from the boot (connections to the fuel tank)?
#6 hungdynasty
hungdynasty
  • 175 posts
Posted 23 May 2022 - 03:31 PM
[images]
Attached File  WhatsApp Image 2022-05-23 at 11.28.15 PM (1).jpeg   34.15K   7 downloads
Attached File  WhatsApp Image 2022-05-23 at 11.28.15 PM.jpeg   31.85K   6 downloads
Attached File  WhatsApp Image 2022-05-23 at 11.28.14 PM (1).jpeg   35.09K   5 downloads
Attached File  WhatsApp Image 2022-05-23 at 11.28.14 PM.jpeg   37.65K   6 downloads
Attached File  WhatsApp Image 2022-05-23 at 11.28.10 PM.jpeg   27.27K   4 downloads
Attached File  WhatsApp Image 2022-05-23 at 11.28.05 PM.jpeg   46.18K   5 downloads
#7 sonscar
sonscar
  • 3,085 posts
Posted 23 May 2022 - 05:28 PM
Fair play if you want original looks,nothing at all wrong with that.Looks to be a complex construction just to enable the subframe fitting on the production line,and how often do you remove it?Keep up the good work,Steve..
#8 humph
humph
    How bad can it Be?
  • 1,114 posts
Posted 24 May 2022 - 11:48 AM
I'd recomment that you don't use the OEM injection fuel filter with the screw on unions, they rust solid and are a real pain to change at service time.  I've swapped mine for a widely available one with push on fitments. The one I have is the correct length  diameter to fit in the existing holder.
https://catalog.mann...l Filter/WK 512
https://www.eurocarp...ASABEgIvUfD_BwE
Edited by humph, 24 May 2022 - 11:52 AM.
#9 fokko
fokko
  • 167 posts
Posted 26 May 2022 - 11:20 AM
Yes, seems like you have a good point, but if you ever have to remove the subframe, it’s a real PITA if you routed the fuel lines underneath  :lol:
And thanks for the compliment!
Thanks for the advice! I already have all of the pipework and filter, including the bracket (from DSN classics). I’ll give it a good smear of copper grease…
Edited by fokko, 26 May 2022 - 11:21 AM.
#10 Deeppockets
Deeppockets
  • 103 posts
Posted 27 May 2022 - 05:52 AM
It is also worth noting the filter and fittings changed in the last couple of years of production . The fitting reducer/adapter WKB10019 can be deleted if the later setup is used. Requires filter WJN101190 and tank-side line WKB10018L.
Fuel tanks, fuel pump and fuel systems - multi point injection : Somerfo... (somerfordmini.co.uk)
The clips that secure the 3 lines to the seat back in the boot are fairly rare now. These can be secured with an M8 through the panel and a hex furniture cap on the clip to hold securely if you have difficulty with the factory metal screw stud.
