Putty? Door Window Winders
Posted 25 May 2022 - 12:20 PM
3 Years ago when I started the project and removed the winders I balled up the old putty but itโs now in the 5th dimension somewhere!
Has anyone replaced their putty and what did they use?
Apologies for this somewhat stupid question, as I am tending to think that blue-tack might well do.
Thanks in advance. ๐
Posted 25 May 2022 - 12:24 PM
I'm planning on using some "Denso tape" when I fit mine again.
Posted 25 May 2022 - 12:45 PM
It's body caulking. It used to be available in packs like plasticine, don't know if it still is.
https://www.3m.co.uk...p/d/v000170319/
Posted 25 May 2022 - 01:00 PM
A much less messy solution I came up with and easier if you ever have to remove the regulator in the future for whatever reason (itโs a mini nothing is ever fit and forget) was to use d profile door and window draft excluder stuck to the regulator.
I used this stuff to seal virtually every joint during my Morris Traveller resto. I think it will do the job for you and a great price too
Posted 25 May 2022 - 01:24 PM
Posted 25 May 2022 - 02:56 PM
I used pipe insulation lagging did the trick and kept it all tidy
Posted 25 May 2022 - 04:27 PM
What kind of lagging?
Posted 26 May 2022 - 04:55 PM
RefriTech pipe insulation lagging
https://www.ebay.co....ar=493905502414
I also used it behind the door latch mechanism to stop it vibrating against the door. (the long metal part)
Edited by weeally, 26 May 2022 - 05:00 PM.
Posted 26 May 2022 - 05:19 PM
