Hi,
I've just put my engine/gearbox back in the car after reconditioning the gearbox (baulk rings / bearings etc).
I wanted to test the new clutch, so sitting in the car I pushed the clutch down but struggled to move the car back and forth in 1st (pushing it) which didn't seem right to me.
Cut a long story short the clutch is fine, I proved this by removing the flywheel and thereby taking the clutch out of the equation, so I am now just on gearbox resistance. Bell housing is on and engine sitting in engine bay. I am still having slight problem pushing it back and forth in gear and want to check if this is normal?, or am I inventing a problem that is not there..?
I can push the car with no resistance in neutral, as expected. 4th gear limited resistance, with each selected gear up to 1st making the car slightly more difficult to push. In 1st I have to put some effort in to get the car to to move (same with reverse), but not hernia inducing. There is however a discernible difference between 1st and 4th.
I can hear all the gears engaging with no sounds I would not expect to hear, although 1st and 2nd can be a little reluctant to engage until one has been gently persuaded, then fine.
The box is currently dry.
Part of me thinks I should feel no difference whatever gear is selected (when disconnected from the engine), but I can also reason the shorter the gear this might be expected.
Any ideas if if is normal to feel a difference in resistance turning the gearbox in 4th as opposed to 1st? And it's not correct any suggestion on what I've done wrong? (it has a 2.9 diff in, A+ gearbox)
Thanks Matt
