Finger Sander/file
16 replies to this topic
#1 Gaz66
Gaz66
  • 953 posts
Posted 31 May 2022 - 10:45 AM
Can anyone recommend a finger sander?
Ive looked around the net and theres quite a few to choose from but all seem quite bulky apart from the silverline one which is very slim.
Are all the belts the same size across the board?
#2 stuart bowes
stuart bowes
  • 2,214 posts
Posted 31 May 2022 - 10:57 AM
I've got this one and it works quite nicely
https://www.amazon.c...r/dp/B000XG3ORW
very lightweight, easy to aim and target small areas ?
couldn't tell you if same size belt as other units, only ever had that one
Edited by stuart bowes, 31 May 2022 - 10:58 AM.
#3 weeally
weeally
  • Just Joined
  • 130 posts
Posted 31 May 2022 - 11:23 AM
I have the silverline one and it has done the trick during my rebuild
#4 nicklouse
  • 18,662 posts
Posted 31 May 2022 - 11:29 AM
There are different sizes.
air or mains or battery powered?
#5 Gaz66
Gaz66
  • 953 posts
Posted 31 May 2022 - 11:59 AM
Mains powered Nick
Are the belts for the silverline easily available weeally?
Edited by Gaz66, 31 May 2022 - 12:05 PM.
#6 nicklouse
  • 18,662 posts
Posted 31 May 2022 - 12:07 PM
Clarks or black and decker.
I have a whole pile of silver line ones i got of eBay for my air one (not silver line).
#7 jonlad
jonlad
  • 325 posts
Posted 31 May 2022 - 01:35 PM
I saw the title of this thread and initially thought "my grinder and flap disc does a good job of sanding my fingers when not careful"   :lol:
#8 stuart bowes
stuart bowes
  • 2,214 posts
Posted 31 May 2022 - 05:26 PM
yeah it'll definitely do that
#9 Midas Mk1
Midas Mk1
  • 5,786 posts
  • Local Club: S.U.N.M.C
Posted 31 May 2022 - 06:38 PM
Black and decker one has a plastic wheel which wears down when grinding welds.
Im using this one with good success
https://www.screwfix...cB&gclsrc=aw.ds
#10 nicklouse
  • 18,662 posts
Posted 31 May 2022 - 06:47 PM
#11 weeally
weeally
  • Just Joined
  • 130 posts
Posted 31 May 2022 - 06:54 PM
Mains powered Nick
Not had a problem getting them. Think they are 13mm x 475mm . Get them from screwfix, amazon and ebay.
Guess it will depend on what size you are looking at, i do believe there are smaller ones
Edited by weeally, 31 May 2022 - 06:55 PM.
#12 Gaz66
Gaz66
  • 953 posts
Posted 31 May 2022 - 07:45 PM
Ive got my eye on the same one but also looking at an air one but that means a compressor which I haven't room for.
#13 MaximMini
MaximMini
  • 226 posts
Posted 01 June 2022 - 06:53 AM
What I found with my belt sander is the importance of the sanding belts. I went from the cheap ones which came with the machine to Klingspor and finally to 3M Cubitron and still can't believe what differences I saw. With the cheap ones I was close to not use the belt sander any more. The Klingspor ones were much better with regards to grinding capabilities and service life but would rip easily. Finally, following a recommendation from a friend in the trade, I tried the 3M Cubitron (the violet ones) and while being much more expansive, they are of a different league. The service life is very good and while they don't tend to rip at all, I started to keep used belts for occasions where I would not need to remove much material (and only ever buy 60 grid).
#14 Gaz66
Gaz66
  • 953 posts
Posted 06 June 2022 - 05:47 PM
Well I got the evolution sander and Im well impressed. I got some screwfix belts and it seems to go through them quite rapidly with a few shredding but to be fair they were catching on sticky out bits of sharp steel.
Will try some of the posh belts mentioned if I can source them as I can see me going through a lot!
#15 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 06 June 2022 - 07:43 PM
I use a Makita mains powered one. It's a great tool when you need something like that. Good to hear 3M make belts, worth trying once I run out of Makita ones.
