Hi all,
I'm new here and currently working on my 2000 Mini Cooper S that has been sitting for years.
Three things I'm a bit worried about are the following:
- this is how my engine looked like with the thermostat and thermostat housing removed, I have flushed the system completely with a garden hose and the water coming out now is 95% clear water. Would I still need to address this further? Image: https://imgur.com/QmlEUmL
- this is what came out of my radiator (after flushing the radiator and engine block with a garden hose), a bit of oil looks to be in there, would that be a sign of blown head gasket? Note that no oil (or oil like substance) was found when flushing the engine block. Image: https://imgur.com/DNUk9YM
- this is how my coolant reservoir looked like, it was completely empty (I vaguely remember it boiling(?) the coolant years ago before putting it away). I'm worried about the brownish debris on the bottom of the reservoir. Would that indicate something? Image: https://imgur.com/NfBW8j4
Many thanks for your thoughts in advance.
Regards,
