Battery Cutt Off Switch Wiring Help
5 replies to this topic
#1 MiniFanGraham
MiniFanGraham
  • 119 posts
Posted 12 June 2022 - 03:16 PM
Hello
Just looking to wire in a battery cut off switch this weekend
I have this image see attached
I understand most of this, what I'm not sure about is the 2 wires to terminals marked 2
I have current wiring from ign switch to coil, etc, are these wires to terminals marked 2 seperate to that or intended to cut into current circuit?
the terminal marked 2:
one goes to Ignition switch - but where on the ignition switch does this go
is it just a jumper wire from ign switch or do I cut the current wiring so one end comes from ign switch to cut off switch
and then other is from cut off switch to coil
the other goes to ignition coil, which terminal on ign coil ? - is this a jumper wire or cut into wire so switch is in middle
thanks for help in advance
#2 ac427
ac427
  • 733 posts
Posted 12 June 2022 - 03:29 PM
At a guess i would say the two terminals for position 2 are to break the circuit between the ignition switch in position 2 (+12v to coil) and the positive terminal of the ignition coil.
The positive terminal of the coil should be marked but you could also use a multimeter or the cable colour to see which one it is/should be.
Edited by ac427, 12 June 2022 - 03:30 PM.
#3 Avtovaz
Avtovaz
  • 1,306 posts
Posted 12 June 2022 - 04:42 PM
the idea is when you crash etc, and someone pulls the pull cord,  the ignition is cut so the engine stops. So you need to cut the feed to the coil, or the ignition cable. Id do the feed to the coil its easier. Also the alti is still generating lekky until the engine stops, and that has to go somewhere or it damages the diodes in it, so that s what the resistor is for.
#4 sonscar
sonscar
  • 3,198 posts
Posted 12 June 2022 - 07:25 PM
Disconnecting the battery while running will not stop the car if the alternator is working.Steve..
#5 KTS
KTS
  • 2,490 posts
Posted 13 June 2022 - 08:31 PM
...but cutting the ignition circuit will
#6 sonscar
sonscar
  • 3,198 posts
Posted 14 June 2022 - 06:14 AM
Yes,that is why the above switch is wired as such,and the basis of the OP question,Steve..
