Hello
Just looking to wire in a battery cut off switch this weekend
I have this image see attached
I understand most of this, what I'm not sure about is the 2 wires to terminals marked 2
I have current wiring from ign switch to coil, etc, are these wires to terminals marked 2 seperate to that or intended to cut into current circuit?
the terminal marked 2:
one goes to Ignition switch - but where on the ignition switch does this go
is it just a jumper wire from ign switch or do I cut the current wiring so one end comes from ign switch to cut off switch
and then other is from cut off switch to coil
the other goes to ignition coil, which terminal on ign coil ? - is this a jumper wire or cut into wire so switch is in middle
thanks for help in advance
